May 21, 2026, 03:29:19 am
mvptkfjb
Ladder bars and coilover how-to?
Topic: Ladder bars and coilover how-to? (Read 5766 times)
SixGun
October 02, 2012, 13:37:18 pm »
Some ladder bars for "dummies" questions..
How do i decide what is the correct length of the ladder bars for my car? 78" wheelbase, and hmm... around 1300lbs weight maybe.
Are the RLR bars what i should get, or are there other options?
Any other information on positioning etc is also welcome. I need to learn
And any suggestions for coilovers?
Last Edit: October 02, 2012, 13:39:31 pm by SixGun
Re: Ladder bars and coilover how-to?
October 02, 2012, 14:15:04 pm »
Mount the gearbox 1st.measure from the axle forward to the main hoop in the cage,thats your ladder bar length,give or take,you need a good solid mount at the front and the traditional way is to run 2 tubes across between the cage main hoop and take your brackets off them.As they will be custom length you are better getting them made locally,or at least in the same continent that you live
not sure where you are in the world but Jim smith does some good bars and I am sure he can do them to whatever length you need,try to mount the coil over on top of or behind the axle,not in front of it and as straight as you can
There are lots of pics out there that should help you
SixGun
October 02, 2012, 14:28:01 pm »
Thanks man, only thing is that the cage isnt made yet, and when googling around i found various answers regarding ladder bar length and how the car would react...thats why my question popped up
But if im good anyway, i will just have the cage made without taking ladderbar length into consideration, then just have them made to the length needed when the cage is done.
Btw, im in Norway.
Jim Smith
October 02, 2012, 14:28:56 pm »
Take a look at ` NSU Prinz 4 ` build up pics in `In Da Works` As Richie says, there is no real hard and fast rule when it comes to ladder bar length. 32" is talked about alot, but that just happens to be the distance from the axle centre line to the point most Beetles have thier main hoop mounted???!!!
I have very very short bars on mine and it all works fine.
Thanks Jim
www.cotsweld.co.uk
Race car fab 01242 232084
SixGun
October 02, 2012, 14:36:33 pm »
Thanks Jim, i've been following the Prinz thread, great build! And i understand that you are the masterbrain behind the cage and suspension - lookin real good!
I guess i should not worry then. Thanks for your quick replies guys
October 02, 2012, 16:24:13 pm »
Quote from: SixGun on October 02, 2012, 14:28:01 pm
Btw, im in Norway.
The main hoop has to be above the drivers head,it is a fixed point effectively,so then with the gearbox fixed you have your maximum length,personally I think you try to make the ladder bars as long as you can,there should be less geometry changes that way, a short bar has a reputation for being more violent,and lots of early chassis cars crashed with short bars,but time has shown this may not have been due to the bar length,but some other design issue
jamiep_jamiep
October 03, 2012, 09:41:15 am »
Where are you six gun?
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
SixGun
October 03, 2012, 09:47:01 am »
Im in Norway
