October 14, 2026, 05:32:34 am
| |-+  For sale!
| | |-+  2276 Turbo or IDA motor...
Author Topic: 2276 Turbo or IDA motor...  (Read 3670 times)
71CALRIPPER
« on: June 24, 2007, 19:04:11 pm »
C.B. high roof Alum case/shuffle pinned/tapped/oil holes/full flow
C.B forged 82mm nitrided crank w/chevy journals
C.B. H-beam rods
Engle cam FK87
CB/SLR lifters
C.B. straight cut gears
Chrome moly lightened flywheel
Moly gland nut
Moly head studs and pushrods
Mahle piston kit/teflon buttons/total seal rings
C.B. #1411-Wedge port/Wedgeport heads/ported,polished 44x37.5
Scat rockers w/stock  valve covers
all bearings are german 30mm oil pump w/full flow cover
Deep sump
fully balanced
8.5 compression
Balanced ready to go!
Will have videos of this engine being run in with the full turbo system, should make 350 hp Smiley
2800k ovno with front part of the header and outlet for the turbo or  the compression can be moved up to 10.1 and you can have a large IDA motor
This engine was built 100% the same as this 10s street car.
« Last Edit: June 24, 2007, 19:30:12 pm by 54caldub » Logged
