October 13, 2026, 23:10:46 pm
| |-+  For sale!
| | |-+  Megasquirt MS2 ECU, Wiring, Sensors, Coil Pack,Jaycee Crank Trigger Pulley
Author Topic: Megasquirt MS2 ECU, Wiring, Sensors, Coil Pack,Jaycee Crank Trigger Pulley  (Read 4416 times)
Adele AW
« on: October 17, 2012, 19:15:46 pm »
Price £300 ONO
Included: Mesgsquirt ECU, Wiring Harness, Air Sensor, Crank Trigger Sensors (Sensors we dont have are the Throttle Position Sensor and Oil pump as these were damaged in the crash but these are off the shelf items) Jaycee billet Crank Trigger Pulley, MSD short leads, MSD coil pack, ECU to laptop cable, Crank Trigger Sensor Case fitting.
ECU is a MS2 running wasted spark 4 cylinder set up for 36-1 crank trigger, can run N/A or turbo up to 23.5psi of boost with internal map sensor. We had no issues at all with this ECU and it did exactly what we wanted it to do, the software was also pretty easy to set up. It doesn't have a SD card slot, but you can datalog live if you wish as we did via a small notebook.
All the wiring on the harness is labelled to the sensors/ecu so it is extremely easy to wire in. The Jaycee pulley has been modified for 36-1 setup, it is the same on the photo below except blue (it was remade by Marco after we crashed) The MSD Coil Pack is also the same as in the photo below.
O/FF 621
LGK
« Reply #1 on: October 17, 2012, 21:31:35 pm »
Mail for you Adele/Steve.
Best regards Steve
Adele AW
« Reply #2 on: October 17, 2012, 21:40:32 pm »
Best regards Steve
Hi Steve, just replied!
O/FF 621
Adele AW
« Reply #3 on: October 18, 2012, 10:05:11 am »
Sold, Thanks Smiley
O/FF 621
