September 02, 2026, 01:58:07 am
| | |-+  Best tyre combo for a street car
Author Topic: Best tyre combo for a street car  (Read 18682 times)
slammedresto
« on: October 25, 2012, 22:07:50 pm »
Im working on a deal for a 61 cal looker, it lowered on adjusters on the front, stock rear
It currently has BBT steel sprinstars, both 5.5s i think
Im in the UK, anyone have any advice on the best combo of tyres to get a nice stance
I was thinking 145/80/15 up front and maybe 195 0r 205/70/15 rears
been scouring thesamba and here to see what looks best, but also interested in what works well in practice
ALB
« Reply #1 on: October 26, 2012, 05:37:40 am »
With the availability of different sizes these days there are nicer tires than 135's and 145/15's. 185/60's (23 3/4" tall), 175/60's (23 1/4") or 175/65's (just under 24"), or 165/65's (23 1/2") will all handle and brake much better than what you're contemplating.  I have runboth 135's and 145's and they can be scary in a panic stop (especially with front discs) when the road is wet or dusty. If you're looking to put somehting together that is fun (and safe) to drive then a liittle wider than a 145 would be a good idea.
For the rear you might want to look at something a little shorter than a 205/70-15; at almost 27"tall, unless you're running a big motor they'll suck the acceleration out of your car. A 195/65 (just under 25") or 205/60 (almost 24 3/4" ) are both very close to stock height and might be more practical on a car that's driven.  Of course, if all you're after is the look....
slammedresto
« Reply #2 on: October 26, 2012, 11:08:57 am »
Its just going to be a dry day weekend warrior, just a fun car, not a daily driver. It will have a 1641 for the time being.
I'm after the right look, but want it driveable. I'm not sure what  combos other UK Members have chosen,
streetvw
« Reply #3 on: October 26, 2012, 13:42:08 pm »
145 up front but see if you can swap the 5.5" front sprints for 4.5" ones then either a 195/65 or 185/70 rears
this ones 145 on 4.5" fronts and 185 on 5.5" rears
« Reply #4 on: October 26, 2012, 15:56:46 pm »
i've the same combo on my 61 xzx 145 in front & 185/70 pirelli cinturato cn 36 at rear
« Reply #5 on: May 20, 2013, 20:47:28 pm »
I was searching some info and ideas as I have to change all 4 tires on my 68.
I'm currently using 145/15 front and 165/15 rear. Wheels are early Fush 5.5 and 6". The front is lowered only using CB perf drop spindles. It drives well, handle well, but I'm looking for something different.
I don't know which way to go. 145/15 and 185/70 rear?
                                            145/15 and 195/65/15?
                                   or      175/65/15 and 195/65/15.
I fear to have rubbing issue with 175 front tires. Do any of you is using this dimension with drop spindles and a stock beam?
Thxs   Wink
« Reply #6 on: May 20, 2013, 20:51:36 pm »
I'm really happy with 165-65 and 205-65 both on 6" rims.
Had 155-65 and 195-65 but now it's better Smiley
« Reply #7 on: May 20, 2013, 20:57:09 pm »
Is your beam stock or narrow? How do you lower it?
Thanks.
« Reply #8 on: May 20, 2013, 21:08:44 pm »
Stock with avis adjusters. Short Bugpack dampers.
Rear I have 5 lowered inner and 5 raised outer splines.
With 215-65 MH DOT tires I can slip my fingers to the knuckels between tire/wing.
slammedresto
« Reply #9 on: May 20, 2013, 21:57:51 pm »
as an update, i bought the car and got it with a set of original lemmertz sprints, 4.5s front and 5.5 rears
spillo491
« Reply #10 on: May 21, 2013, 18:35:34 pm »
Cool, other pcitures ? Tyres size and brand ?
slammedresto
« Reply #11 on: May 21, 2013, 20:58:24 pm »
145/15 michelin xzx up front, 4.5" lemmertz sprints, 195/70/15 michelin x(from memory) on the rears, 5.5" lemmertz sprints
slammedresto
« Reply #12 on: May 21, 2013, 21:00:58 pm »
before i bought it , it was mocked up on a set of centerlines, id love to get a set in the future
« Reply #13 on: May 22, 2013, 15:33:01 pm »
She sure looks nice  Smiley!
I still don't know what to choose though  Tongue
I like the classic look of the 145 and 165 tires, I don't need wider tires with a 1641cc engine but wider tires always looks mean.
spillo491
« Reply #14 on: May 22, 2013, 19:29:20 pm »
Thxs   Wink
175 on front
spillo491
« Reply #15 on: May 22, 2013, 19:47:05 pm »
I'm also very unsure about which tires fit on my 4.5 and 5.5 SA Sprintstars
I love classic look of Michelin zx 145 front / 185 rear but 185 are soo expensive ... then someone says that 145 are too narrow
Vredstein are nice but 155/80 overall diameter is too high for the front .....
Other choices with classic look ?
« Reply #16 on: May 22, 2013, 21:32:35 pm »
On this pic I had 155 firestones in the front en 205/70 in the back. Should have never sold those tires and gone for 135..  Embarrassed
spillo491
« Reply #17 on: May 23, 2013, 08:11:40 am »
Mmm, it seems nice, have you other pcitures ?
« Reply #18 on: May 23, 2013, 08:52:27 am »
Quick find.
spillo491
« Reply #19 on: May 23, 2013, 14:03:13 pm »
Front BRM size ? I have 4.5 .... thank you  Wink
« Reply #20 on: May 23, 2013, 14:25:21 pm »
Everyone has their own opinion on what looks right, works right, etc. Just buy a set of damn tires and see for yourself already Roll Eyes Wink
« Reply #21 on: May 23, 2013, 15:01:46 pm »
Flat 4 so I believe 5 inch?
« Reply #22 on: May 23, 2013, 15:06:01 pm »
Sure, but the trial and error tests are quite expensive in this case  Tongue
And as we basically all drive the same car, reading what others have to say is always good info to build itself an opinion  Wink
spillo491
« Reply #23 on: May 23, 2013, 15:10:07 pm »
The forum is used in this  Smiley
RIP356
« Reply #24 on: August 01, 2014, 03:07:56 am »
Sorry to bring this back up!
I am looking for some tyres/tires for my short rear axle bug
I will be running 5 and 6.5 BRM copies, looking at 155 on the front and 205 x 70 on the rear.
Any recommendations, I priced up Verdestein rears and they are $500 each!!!!
Iryanu
« Reply #25 on: August 01, 2014, 08:06:14 am »
I got a pair of Michelin XWX 205/70 for £55 each off ebay! I don't flinch when smoking them.  Grin Cheap as chips! £270 new each!
Just looked on ebay, there's another single one on there for £55 including postage. But it's in the UK so I guess no good for you.
RIP356
« Reply #26 on: August 04, 2014, 01:19:20 am »
Would 155x65 be alright on a standard front with adjuster dont want to go too low
