October 12, 2026, 16:45:56 pm
Off Topic
Seatbelts in a 61
Topic: Seatbelts in a 61 (Read 6928 times)
slammedresto
Seatbelts in a 61
October 28, 2012, 23:39:27 pm »
Whos done what??
just bought a 61, and want to make it safe to take out my 5 yr old, so really have to fit belts,ideally 3 point for the car seats in the rear, lapbelts for the front is fine but unsure where i start, as im sure the 61 had none
Re: Seatbelts in a 61
October 29, 2012, 17:45:47 pm »
At some point in the '60s, VW started putting the mounting points in for seat belts. I do not know when exactly. Do some searching around in the car, easiest place to check first is under the back seat bottom. Also, you can probably feel if the holes are under the headliner in the C-pillars.
Fritter
October 29, 2012, 22:49:02 pm »
No factory mounts in a 61. If you buy the belts from Wolfsburg West, they include instructions and hardware to install belts in cars that never had mounts. Basically, you drill holes in the floorpan and mount with big washers.
Mike F.
'64 Indigo Blue sunroof Bug
slammedresto
October 29, 2012, 22:57:14 pm »
im thinking of fitting 3/4 point harnesses in the front now, and 3 point retractables in the rear for the child seats
anyone running harnesses with stock seats?
Chris W
October 30, 2012, 01:30:30 am »
This is how I did mine on the outside of the pan up front.
RichardinNZ
November 02, 2012, 20:47:05 pm »
Fitted 3 point retractables I the front of my '58 with semaphores (which limits height of 3rd mount). Coming from the UK and having done similar things there (including article for the old TotalVW magazine with Quickfit), the rules and signoff needed here in NZ seemed a pain at first but very happy now as it results in a good factory style installation where belts can be removed without washers etc dropping to the ground . No welding needed!. I can post pics if you are interested.
Only put 2 point lap belts in rear as my chidren are older and out of car seats.
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
