September 23, 2026, 07:51:26 am
| |-+  For sale!
| | |-+  Engine Type 4 with Remmele special cylinder heads 2,9 l
Poll
Question: Engine Type 4 with Remmele special cylinder heads
Engine Type 4 with Remmele special cylinder heads - 0 (0%)
Engine Type 4 with Remmele special cylinder heads - 1 (100%)
Total Voters: 1
Author Topic: Engine Type 4 with Remmele special cylinder heads 2,9 l  (Read 2881 times)
blasemaus
« on: November 14, 2012, 13:43:14 pm »
2.9 liters
Motor housing with 105mm special pistons and cylinders
84 mm stroke crankshaft
Pauter camshaft 322
Camshaft degree dovetailed
Bearing set (main and rod bearings camshaft) ago Last year new
Flywheel bolts Bas Special
Oil Pump enhanced
Oil sump extension
Aluminum pulley
Oil pressure switch
Oil Filler steel
Remmele special cylinder heads, 105 mm bore
Titanium inlet valve 50 mm, 42 mm titanium exhaust
11:1 compression
Reinforced valve springs
rocker arm
Alternators run deeper milled for long hood
vent connection
Pushrods Aluminum
Ventileinstellschrauben with ball feet
Aluventildeckel Remmele with exhaust ports
Cylinder studs
Pushrod tubes longer execution
Blower box Carbon
Motor end plate carbon fiber
Clutch Pressure Plate 200mm
Driving plate 200 mm
Intake manifold 4 hole 54 mm
Remmele 54 mm throttle bodies
injection
Controller, programmable
Laptop program for injection
Harness for injection
Oxygen sensor
Intake air
catch Tank
Kurbelgehäuseentlüfterbox with all hoses and connections
  Remmele Airfilter
Exhaust 48 mm
Engine was overhauled last year completely. Raced for 100 km
Torque Nm 310 about 260 to 265 hp
Price: basis for negotiation 18000,- Euro
Fon: 0176 64923328
