July 24, 2026, 12:35:42 pm
| | |-+  010 without points
Author Topic: 010 without points  (Read 15504 times)
Whyshchuck
« on: June 27, 2007, 02:10:49 am »
Hello
Do you know if it's possible to install systems like compufire or illuminition in 010 without any remakes?
« Reply #1 on: June 27, 2007, 02:44:09 am »
http://www2.cip1.com/ProductDetails.asp?ProductCode=PER%2D1844
Pertronix kit from CIP1.
« Reply #2 on: June 27, 2007, 03:10:16 am »
Pertronix 1844N6 for 6 volt modules
Whyshchuck
« Reply #3 on: July 23, 2007, 10:27:21 am »
but I've also heard that Pertronix aren't very realible. Are they?
« Reply #4 on: July 23, 2007, 14:58:46 pm »
I've used them for years and I'm using one in my daily driver right now. I did have an issue with one about 15 years ago where the rivets that hold down the module worked loose and caused some misfiring. Also if you hook them up backwards they fry.
Rune
SCC Crew
Screwdrivers #7
« Reply #5 on: July 23, 2007, 20:05:15 pm »
I have a pertronix in my 010 (12V). Worked flawlessly for a couple of years now..
« Reply #6 on: July 23, 2007, 22:50:44 pm »
Why do these things "give you twice the voltage to your spark plugs"?
« Reply #7 on: July 24, 2007, 00:01:36 am »
The only trouble I had was when the screw that holds the unit down came loose - not really a problem I just tightened it and it has done me well for over 5000 miles  Smiley
Rune
SCC Crew
Screwdrivers #7
« Reply #8 on: July 24, 2007, 13:02:10 pm »
They don't Smiley
« Reply #9 on: July 24, 2007, 19:17:02 pm »
My point exactly!  Wink   Cheesy
