September 23, 2026, 22:30:11 pm
Ballpark jetting for 44idf/2276
Topic: Ballpark jetting for 44idf/2276 (Read 3743 times)
fastoldvw
November 23, 2012, 16:31:22 pm »
Hi, i just bought a used set of italian 44 idf's, and would like to ask the experts if the jetting in them is allright for initial start up..
They came with:
34mm venturis
4.5 sec. venturis
.45 idle
f11 emulsion tube
150 main air corr jet
130 main gas jet
Engine is: 82x94 2276 oxyboxer, engle 120 cam stock rockers, 35X40 valves ported heads/manifolds , .. About 9:1 compression.. Rods are 5.6" long.
Also would like to know of a good supplier of parts for these carbs.. one secondary venturi is a little damaged and i'd like to replace it..
Rune
Oilers Motor Klub, Horn County
benlawrence
Re: Ballpark jetting for 44idf/2276
November 23, 2012, 20:35:11 pm »
I ran a fairly similar spec , your idle jets i would start with 55's 160 main 180-200 air
