July 24, 2026, 17:18:20 pm
| | |-+  Oil lines 356 oil filter
Author Topic: Oil lines 356 oil filter  (Read 5303 times)
Henrik Hagen
« on: December 03, 2012, 21:09:58 pm »
I am searching for oil lines my porsche 356 Mann oil filter. My plan is to fit it to my 1600cc type 1.
I searching for stock looking oil lines but longer so they will fit the filter the way I want.
I need advice please. I dont want to use copper tubing.
Regards Henrik Hagen
hotrodsurplus
« Reply #1 on: December 05, 2012, 11:43:41 am »
The fittings on the Mann housing are quite small. I would remove them and weld or braze AN fittings in their place. Then I would use Aeroquip 100R5 reusable fittings and black 1503 hose. There are probably affordable counterparts where you live. These are all standardized industrial applications. Go to a shop that sells hose and fittings for industrial machines and ask. You can make them any way you want and they will last forever.
« Reply #2 on: December 05, 2012, 12:05:22 pm »
Does one fitting have a restriction in it to limit that oil draw?
Henrik Hagen
« Reply #3 on: December 05, 2012, 17:34:48 pm »
Ok
I will try that...
I was told that the inlet hole should be restricted to 1,5 mm to limit the oil draw. Any opinions about that?
Henrik Hagen
« Reply #4 on: December 05, 2012, 18:48:47 pm »
On a 30 hp engine 1,5 mm may be good. On a 1600 with more reserve in the pump, a large hole is no problem. I think the 356 engine has a 2,5 mm hole. I will check and get back to you.
WRT hoses, you can either send the measures to me, and i will make them for you, or contact "Slangespecialisten" in Stevns. - He is somewhat closer to you.
hotrodsurplus
« Reply #5 on: December 05, 2012, 22:00:40 pm »
Forgive my ignorance, but does this filter work as a bypass or as part of a full-flow system? I assumed that you would use the filter inline as a full-flow part so my suggestion may be excessive.
Henrik Hagen
« Reply #6 on: December 05, 2012, 22:41:33 pm »
I want to use the filter as a partial filter just like porsche.
I have found an industrial 1600 type 1 engine build on AS21 engine block with low hours.
I dont want to disassemble it but give it an old school look and give it an oil filter without drilling the engine block.
« Reply #7 on: December 05, 2012, 23:05:29 pm »
Bypass Smiley
hotrodsurplus
« Reply #8 on: December 06, 2012, 01:03:00 am »
That changes things. If the existing fittings have an NPT thread then you could just adapt them to AN/JIC fittings. JIC is dimensionally identical to AN but is made to slightly looser tolerances and costs a lot less. The AN-style fittings used in industrial applications is JIC. It works fine for our purposes.
As a bypass I bet that you would be fine with -6 hose (6/16, aka 3/8-inch diameter). If you kept the lines short you could probably use -4 (4/16 or 1/4). What diameter did Porsche specify?
I bet it would look very good if you used an industrial hose with a black jacket.
