October 15, 2026, 06:33:37 am
| |-+  For sale!
| | |-+  1 inch (2.6cm) Solid mount Raised Transmissions Mounts
Author Topic: 1 inch (2.6cm) Solid mount Raised Transmissions Mounts  (Read 2390 times)
Paul da Graca
« on: December 06, 2012, 00:54:43 am »
1" transmission raise kit for street or strip use.
Give your car the lowered look with out the extra camber.
One of the down sides when going real low on a swing axle car is the outer wheel bearings do not get correct amount of oil.
With a 1 " raise kit you will raise the gearbox up but will be able to straighten out the axle and correct the camber to get enought oil to the outer bearings.
Rear mount is a bolt in and mid mount will need to be weld in place
send me an e-mail at pdagraca@extron.com or call me at +31640503093
Thanks for looking
Paul
