September 23, 2026, 07:51:08 am
| |-+  For sale!
| | |-+  Selling: Parts and performance, take a look...
Author Topic: Selling: Parts and performance, take a look...  (Read 3625 times)
a4eleiva
« on: December 30, 2012, 20:36:17 pm »
- New, never used: Dell 36 drla w/ stacks, filters, manifolds, linkage, braided fuel lines, with fittings. 750.00
- New, never used; Weber 42 dcnf, with filers, manifolds, Berg linkage, addl' jets. 650.00
- CB 041, light port/polish, new never used, 450.00 pair
- 1 3/4 Merge exhaust, designed by SS Headers (great Company, too bad the stopped making stuff for VW) to achieve maximum RPM & horsepower output; Slip joints on the head pipes allow proper fit; this is a merged system for use w/o heater boxes. Never used. 1 3/4 inch merged system $160.00, dual Quiet Mufflers (cleared for ghia, and bug) for Merge Exhaust $100.00, Chrome stinger, no baffle $25.00
- ‘62 Karman Ghia, deck lid (front) $250.00  and rear seat $100.00; Good condition, basically ready to sand primer and paint, hinges not included, however, has the front lock mechanism.
- swing axle trans, Rancho built, 3:88 r/p $490.00 never used
- Camber compensator for Swing axle Trans, VW; Gene Berg product; Designed To Protect Against Over-Camber; easy bolt on to Trans. $ 60.00.
Vintage Tires: 4 Pirelli Cinturato CN36; Light use; (2) 185 70 15; (2) 215 60 15 VR rated…  Photos available if truly interested. These tires were original equipment on most 911-s  mid 60's to mid 70's; if restoring a 911 from that era, these tires are a must.  They are in very good condition; stored in my garage.
Varied parts, most are new: heads, oil coolers, oil pumps, lighten flywheel (12), oil sump, oil bypass kit, solid mount for trans & motor (Berg), custom merged exhaust w/ duals or stinger, some custom sheet metal, Motorola alternators, polished parts, Scat shifter, etc.
Some additional detail as I go through parts:  Oil pump covers $20./40 depending on year; full flow kit (Berg) requires drilling and threading, but nothing better is available) 90.00 currently 150.00;  Pumps 26mm (Berg) early case/single 70.00; 30mm Schadek $50.00, Melling 30mm, $65.00; Pump covers Berg w/relief $50.00; ss oil line (Berg) set of 4 $80.00 or in sets of 2 $40.00 each (you won't find these hoses for less than 120.0 if you can find them)... Also two set of stock rockers, good used 45.00 each
Photos if interested in any of the above... email me: a4eleiva@astound.net
« Last Edit: January 17, 2013, 20:13:27 pm by a4eleiva » Logged
« Reply #1 on: December 31, 2012, 10:13:03 am »
PM and email sent about the S&S merged header and dual mufflers
thanks richie
bedjo78
« Reply #2 on: December 31, 2012, 12:11:32 pm »
Helo
I am interested with the new DRLA 36 set. Please send me pictures to rahmanmuzamil@yahoo.com
