November 02, 2026, 17:56:37 pm
My 68 standard 1200 model restoration
Topic: My 68 standard 1200 model restoration (Read 51335 times)
Mabbo
January 02, 2013, 00:03:14 am »
Hello,
I have a UK spec 1200 model standard Beetle which is my first car. When I got it I lowered it at the front and fitted some repro Rivieras
It was rotten so I took it off the road to repair it. I bought a 67 1500, raised the back, fitted a 1776 then 1955cc engine and fitted 4 stud Mahle Baby Burners
I drove that daily for quite a few years while I repaired my 68. I eventually sold the 67, kept the engine and fitted it to the 68 with Megasquirt and a turbo.
I sold the turbo and injection stuff and ran it like this for a while
http://img.photobucket.com/albums/v648/themabbo/30062010039.jpg
I then build a mild 2276. CB crank, CB Unitec plus rods, Std lightened flywheel, Stg 1 Kennedy, Engle FK8, Manton pushrods, Mahle 94mm B+P, Scat D port heads, 45 DRLAs
Then I decided to restore it properly as I want to keep it... so the proper work begins:
Removing the previous paint jobs
Some accident damage to repair
Got the body off:
Started stripping it all down:
Had replaced the pans before but not very well, so cut them out
Repairing framehead bottom plate and section of the tunnel
New bottom plate and top hat
Ready for the pans
Started on the body:
Rear tubs and luggage tray out
Some rust to repair under the back window
Lining the new panels up
Welding them in
Putting the back end back together
Checking the door gaps with new doors before replacing the channels
Bracing the body up
Removing the front end
Trial fit of new bulkhead
Welding the heater holes up in genuine channels
Front quarter and channel out
Tacking panels in place and replacing A post
Remains of the quarters off - guttering unpicked
Genuine front quarter in place and original bonnet lined up
Welding in
Donor sections to repair body
Thats it so far
miguel
Re: My 68 standard 1200 model restoration
January 02, 2013, 08:37:06 am »
FUCK that's a big restoration
, i wish you good luk with it
rene
January 02, 2013, 21:28:14 pm »
What a job!! So nice.
fahrvergnugen
January 02, 2013, 21:43:38 pm »
This All looks very familiar
Good job.
http://fast-air.skynetblogs.be/
January 02, 2013, 23:24:19 pm »
Quote from: miguel on January 02, 2013, 08:37:06 am
No, that's pretty standard for a UK car!
Neil, it's looking good, and using genuine parts makes it so much easier! On my car, when it was restored for my brother back in the late 90's, we used one genuine and one repro quarter. We ended up cutting off the repro one and using another genuine one when they became available.
Mabbo
January 17, 2013, 22:17:59 pm »
Cheers for the comments
Moved the car around in the unit and made a start on the drivers side A post. Got the old one cut out and the new one trimmed to fit, ready to weld in:
I got a couple of bits back from the blasters, quite pleased. No holes but a couple of small areas to sort.
Rear valance has a crease in it but overall shape is good and no rot:
Back side of valance, they are not holes that you can see, just dots of surface rust:
Rear cross members, need to repair the ends but no rot:
The underneath, nice and smooth
I forgot to get this section tidied up and sent to the blasters, so will do what I can with it, need to finish getting the old panels off it, started cleaning it up today... the back was plastered in underseal. Needs a bit of love...
Got a bit of work done on the body cut to repair the rear drivers side window, drilled out a load of spot welds around the frame and cleaned it up a little. There is quite a bit of rot at the back around the swage line but it should just be ok to repair the body:
Got both front quarters and front valance in place to see how everything lines up. Looks pretty good so far but the repro valance needs a bit of work. Starting to look a bit more like a car again:
Getting there slowly...
cedric
January 18, 2013, 11:14:37 am »
Nice job
Tourist
January 18, 2013, 11:53:58 am »
Nice one HPMB
Martin.
Mabbo
January 18, 2013, 19:49:08 pm »
Cheers Cedric / Martin
Rich did a bit of work on the donor section for my rear side window frame today while I cleaned up the washer bottle area. He cleaned the back of the panel up and welded up the half moon vent and repaired a little section just below:
This shows some of the damage that needs to be replaced:
Roughly in place:
I spent ages cleaning up underseal and the old wheel well repair panel ready for welding the front quarters on:
Mabbo
January 19, 2013, 22:19:07 pm »
I decided to carry on with the rear side window repair today. Pleased with how it went.
Decided to trim the donor section down a little more:
Cut out the old, cleaned up the surface rust, bit of rust killer, bit of paint:
Panel in place:
Tacked in place:
Will get it seamed up on Monday, and hopefully get the channels and front quarters finished
Type1/DVK
January 19, 2013, 22:57:03 pm »
wow, you've build a brand new one! nice job..
DDD#8 - 14.74sec @ 1776cc - Member of: DVK ~ Der Vollgas Kreuzers -
www.ultimatevw.nl
- and racing engines
Mabbo
January 30, 2013, 22:07:56 pm »
Spent a while on my car today, dont look much different to how it did at the start of the day, but we got quite a bit done.
Trial fit of the new WW pans, line up well. We drilled holes to plug weld to the Napolians hat and the rear cross member section.
Fitted the body and made sure everything lined up well, and welded the rear sections in.
Found some old floor pan bolts and washers, lined up the genuine heater channel bottom plates with the holes in the pans. All line up well.
Got the body back onto the floor and placed lined the top half of the channels up with the bottom plate and got the spot welder out.
Mabbo
February 04, 2013, 22:19:46 pm »
Got some more done...
Napolians hat and floor pans welded:
Lots of plug welds later:
My donor rear valance was pretty good but not perfect. Came back from blasting with no rot to sort out, which was nice. It does have a couple of dents that need sorting and it was cut off the car on one side instead of drilling out the spot welds. I started repairing that.
What I started with:
Copied the profile off the good side of the valance and cut a section out and welded it to the other side:
Will drill a few holes to plug weld when I fit it
My bodywork just above where the heater channel meets the rear quarter had been patched in the past.
Started with this:
Got it tacked in ready for final welding:
My dash had been cut for a modern stereo. I got hold of a donor section to repair it.
Cut the dash section out:
Donor section in place:
Welded in and ground down ready for a skim of filler:
Mabbo
February 09, 2013, 23:46:05 pm »
We got some work done on the quarters today... got them cleaned up and held in place with some panel pins and clamps:
Got both sides welded in, still got to weld the inside:
Not happy with the fuel filler recess on the new front quarter panel. The shape is different to the original. Its more rounded on the front corners, and the recess at the back of the flap looks wrong.
Original:
Mexican:
I think I'll end up chopping out the whole section and welding the original in because it dont look as good as the original, and the flap dont fit properly. Its too square at the front corners and catches the quarter panel.
Its getting there
February 10, 2013, 00:08:44 am »
Bloody hell.......
And I was sooking to myself a bit because I had a front inner and both pan halves to do.........
andy198712
February 10, 2013, 12:29:28 pm »
what make are the floor pans?
nice job here! should last decades for you!
Mabbo
February 10, 2013, 19:49:01 pm »
Wolfsburg West pans
Cheers dude
Jeff68
February 11, 2013, 14:44:46 pm »
Bloody Hell!!.......My hats off to you on this Project!! Great work being done here to resurrect your car. Coming out great! Keep going....you're almost there!
Cheers!!
Mabbo
February 12, 2013, 23:56:03 pm »
Cheers Jeff...
Got a bit more done today. Was 2 steps forward and 1 step back really, but glad I decided to do it.
I found a cut from a genuine rear quarter for sale. I had already fitted a pair of repro tubs, and some Hookeys rear bumper hangers. The plan was to drill out the spot welds of the early bumper hangers and fit a pair of genuine bumper brackets that I sourced. I was going to re use the repro body mounts I removed before. So fitting this panel saved me a bit of work, and Iv not got a genuine tub, and body mount. The fit is great.
The fit inside:
Will get a bit more work done tomorrow.
cedric
February 13, 2013, 08:25:20 am »
Lucky one with youre orginal part... For me its bad repro stuf but it go to.....you do a verry good job!
Mabbo
February 13, 2013, 21:37:31 pm »
Cheers Cedric
Small update. I got the tubs and luggage tray welded in:
I fitted a Hookeys bumper hanger, and removed the early bracket and tidied it up ready for the genuine late bracket I picked up:
Lining up the rear valance ready to be fitted (again!). Put the wings on loose to check it all looked OK:
Mabbo
February 18, 2013, 22:16:17 pm »
I bought a front body cut from a 1969 model, but not a 1200 style. I originally only intended to use the washer bottle recess and surrounding area but decided Im going to modify the valance and use that as its a much nicer shape compared to the repro panel.
Before:
I drilled out the spot welds and cut all the parts out i didnt need and tidied up the lips, removed most of the underseal then we blasted the two sections that I wanted to use.
They came up well with the valance needing a little bit of work, as well as the two bumper slots adding. Worth the extra work though I think
Got the fuel tank supports, washer recess section, wheel well, and valance all fitted and held in place with panel pins
I wanted to spot weld as much of it as possible to make it look factory:
As my bug is a 1200, it only came with a mirror on the drivers door. The passenger side door had no threaded section for the mirror, so I welded my new door up. Needs a skim of filler:
Got the rear valance welded in, needs a little bit of tidying. Look how well the corners of the valance meet with the bodywork. Loads better than repro:
Lined up the Hookeys engine side trays.
I done a little work on the rear crossmembers. This is what I started with:
Cut out a couple of sections to fill the holes for the heating. (My heater channels have also had the heating holes welded up):
Welded up:
Ground down:
Got the rear crossmembers on:
Then I cut out the fuel filler recess:
Old and new to compare:
Lining the old section up:
Tacked in to place;
Mabbo
February 19, 2013, 23:52:31 pm »
Today I got the front valance repaired and fitted. I cut the slots in the front valance and cut out the bit of rust out and let in a new section.
Finished welding the fuel filler recess:
Fitted the passenger rear body mount:
All the welding around the front end is finished other than a few plug welds to do on the bottom of the fuel tank supports. Ill do that once the body is back off the floor:
My wheels arrived. Rears are 15x5 thin lip Formula Vee wheels, the fronts are original 15x4.5 Rivieras:
The wheels are exactly the same other than the raised squares on the spokes on the Rivieras... I will machine this off and detail them to match the Formula Vees, so I will have a set of 4.5 and 5" thin lips.
My seats are stripped down and the frames has been blasted ready for paint, then off to Trimming Tonic in Lancashire.
Not too much welding left to do
Mabbo
March 03, 2013, 00:15:17 am »
I took my seats to the trimmers last week.
I finished off bits of welding and grinding welds down etc. Almost there:
You can see the pan leaning up the wall awaiting the framehead bottom plate. I had already started fitting a Klokkenholm panel, but it was shit, so I cut it back off. Iv ordered one from Machine 7. Should arrive Tuesday, hopefully its a bit better, we will see... then hopefully I can finish the floor
We got my HiPacs fitted:
Made a start on the prep the other day.
Smoothing the rear cross members:
After some filling and sanding to the rear quarters, the shape is getting there:
Bit more to do to the rear valance:
Got some high build on the rear quarters and valance last night. This morning I put some guide coat on and rubbed it down... it showin they needed a bit more work. I sorted the rear quarters and spent some time on the dash, front 1/4s, A posts and B posts.
Got a bit more high build on tonight:
I need to do a bit more prep on the front inner arches and rear inner tubs as they are not as smooth as Id like.
andy198712
March 07, 2013, 16:41:35 pm »
blimey mate!
you keeping this one after all this work? putting a 1200 in it or...?
Mabbo
March 23, 2013, 21:18:42 pm »
Hello Andy. Yeah mate, definately keeping it. It was my first Beetle / first car... I wont be selling it
I have done a fair bit since the last update so the following is not in order or anything. Just a selection of pictures of some of the work.
We spot welded the bottom plate on and replaced the repro brake line brackets with the genuine ones, and repaired the spine section:
After blasting, we seam sealed the joints and painted it 2k gloss black:
Some pics of the colour sanding and mopping:
Paint finish:
Fitting the interior:
One of the engine:
Building the car back up:
The car was supposed to be on display at the Volksworld show, but we got stuck in the snow and couldnt make it. I was gutted, was looking forward to seeing it on display.
Last Edit: March 23, 2013, 21:22:12 pm by Mabbo
andy198712
March 24, 2013, 16:17:14 pm »
Gutted for you mate
would had loved to have seen it!
Gaz1
March 24, 2013, 20:40:14 pm »
Shame the snow spoilt plans but car looks great mate,like the interior choice
71CALRIPPER
March 24, 2013, 20:41:12 pm »
Sorry to here that dude , car looks cool as !!
Reply #29 on:
March 29, 2013, 02:57:54 am »
Quote from: Mabbo on March 23, 2013, 21:18:42 pm
Paint finish:
Uhmmm........fuck me!
Oh, sorry. DAMN that's straight man!
