September 23, 2026, 08:42:51 am
| |-+  For sale!
| | |-+  VDO tach, several VDO gauges
Author Topic: VDO tach, several VDO gauges  (Read 3966 times)
Olaf/DFL
« on: January 11, 2013, 11:26:31 am »
I´m selling the following VDO gauges:
1. row (top down):
- VDO temperature gauge, rare pinstripe dial, 40-120°C, 12V, built 3/1973, diameter 52mm, white needle, top chrome ring, top glass, incl lamp and mounting bracket, SOLD!
- VDO temperature gauge, 50-150°C, 6V, built 12/1971, diameter 52mm, red needle, good black front ring, top glass, incl lamp and mounting bracket, SOLD!
- VDO temperature gauge, 50-150°C, 12V, built 9/1969, diameter 52mm, red needle, good black front ring, good glass, incl lamp and mounting bracket, SOLD!
2. row:
- VDO temperature gauge, 50-150°C, 12V, built 3/1977, diameter 52mm, orange needle, top chrome ring, top glass, incl lamp and mounting bracket, SOLD!
- VDO temperature gauge, 50-150°C, 12V, built 6/1976, diameter 52mm, white needle, top chrome ring, top glass, incl lamp, SOLD!
- VDO temperature gauge, 50-150°C, 6V, built 2/1969, diameter 52mm, white needle, top chrome ring, top glass, incl lamp and mounting bracket, SOLD!
3. row:
- VDO oil pressure gauge, 0-10 kp/cm2 (equivalent to 0-10 bar), 12V, built 2/1976, diameter 52mm, red needle, top chrome ring, top glass, incl lamp, SOLD!
- VDO oil pressure gauge, 0-10 kp/cm2, 12V, built 1/1971, diameter 52mm, white needle, top chrome ring, top glass, $60 / £38 / €45
- VDO oil pressure gauge, 0-10 kp/cm2, 12V, built 12/1976, diameter 52mm, white needle, top chrome ring, top glass, incl lamp, SOLD!
4. row:
- VDO oil pressure gauge, Skala 0-10 kp/cm2 (equivalent to 0-10 bar), 12V, built 7/1977, diameter 52mm, red needle, top black front ring, top glass, incl lamp and mounting bracket, $60 / £38 / €45
- rare VDO tach, scale up to 8000 RPM, for 6V or 12V use, adjustable for 2-, 4-, 6- and 8-cylinder engines, built 10/1973, diameter 80mm, red needle, adjustable orange needle for gear-shifting speed, good chrome ring, glass has one slight, hard to see scratch below the thumb wheel, incl mounting bracket, SOLD!
Matching gauge panel mounts:
- VDO mounting bracket for three 52mm instruments, original packaging, bevelled edge makes a perfect compliment to VDO Cockpit Black gauges, texture is similar to VW dash, incl mounting hardware, $60 / £38 / €45
- SMITHS mounting bracket for two 52mm instruments, original packaging, bevelled edge makes a perfect compliment to VDO Cockpit Black gauges, texture is similar to VW dash, incl mounting hardware, SOLD!
Will ship worldwide!
Europe: €10 / £9
World: $20
« Last Edit: January 19, 2013, 10:28:50 am by Olaf/DFL » Logged
jay c
« Reply #1 on: January 11, 2013, 16:07:01 pm »
Pm sent
Olaf/DFL
« Reply #2 on: January 11, 2013, 18:52:21 pm »
VDO tach and first temperature gauge in second row are sold!
Thanks jay c!
jay c
« Reply #3 on: January 11, 2013, 19:45:38 pm »
Nice one Olaf
Russell
« Reply #4 on: January 18, 2013, 19:41:27 pm »
PM sent, thx
Best Regards
Russell
