October 13, 2026, 03:08:47 am
| | |-+  Narrowing Axle Tubes, what's the best way?
Author Topic: Narrowing Axle Tubes, what's the best way?  (Read 4674 times)
« on: January 22, 2013, 00:21:30 am »
I've got a pair of Short Axle tubes I need to narrow 5 inchs each side.
What is the best method to do them, cut in the middle?
Any help appreciated!
Lee
« Reply #1 on: January 22, 2013, 00:32:56 am »
I've never tried, but couldn't you remove the tube from the end casting, shorten it and reinstall?
Terry Hoogstins
« Reply #2 on: January 22, 2013, 04:45:19 am »
Remove the lock pin in the casting , press out the tube , shorten the tube and press the casting back on and reinstall the pin. It does require a press ( tight fit ) and install a new boot when the end casting is off Wink
busgods
« Reply #3 on: January 22, 2013, 08:10:50 am »
Just adding to Terry's list.
- Measure everything before you remove the old tubing!  Wink It's fairly important that the shortening is exact.
- You might need to remove the brake line clips from the tube and weld them on after you're all done. Unless you have detachable ones already...
- You need a suitable tube to push the old one off the casing. You can use and old short piece of axle tubing, maybe slightly grinded undersize or just use lathe to make a suitbale. Sometimes the axletube requires a bit of heat to come off. Press stand needs to be pretty big and sturdy. Those pipes are built to stay inside that casting...
- I did my cutting with a hand grinder. If you have a good sturdy pipe cutter at hand, use that. Also, cut enough, otherwise you end up pressing the pipe back out and milling it again...
- Old side cover is a great backing plate when pressing the casting back into the tube. Measuring the new desired length is easy when you're pressing the casting back little by little.
- Make sure you drill and put the pin back on!!!  Grin
« Reply #4 on: January 22, 2013, 18:19:49 pm »
Thanks guys,
Measure twice, cut once Grin
