September 14, 2026, 01:21:11 am
Bad Habit
mid mount for gearbox
Topic: mid mount for gearbox (Read 10049 times)
wolfswest
February 01, 2013, 12:31:13 pm »
Hi guys,
I was wondering if there are any mid mounts for the gearbox on the market that doesn't require welding? if so: links? brands?
AND are they any good? or is it a makes you feel good part that doesn't work like the ones you need to do some welding?
Dem
gizago
Re: mid mount for gearbox
February 01, 2013, 13:00:40 pm »
On my wife's 67 we have a "Mohr style" mid mount, that bolts to the nose cone like all the others but presses against the chassis. Can't comment on how it works yet as the car hasn't been on the road since it was fitted. Ill try and get a link/ picture for you.
Here, like this-
http://m.vwheritage.com/productDetails.cfm?iItemID=163449
Last Edit: February 01, 2013, 13:05:00 pm by gizago
wolfswest
February 01, 2013, 13:38:26 pm »
Thx, that's the model I'm looking for.
Now we need some user reviews.
February 01, 2013, 16:34:06 pm »
Hey Dem,
I have one, but it was a nightmare to fit.
it does work though, but next time i ll use a weld in mount...
gizago
February 01, 2013, 19:33:34 pm »
Mine wasn't bad to fit at all. What gave you problems Peter?
wolfswest
February 01, 2013, 20:07:38 pm »
Quote from: gizago on February 01, 2013, 19:33:34 pm
yeah, which problems did you encounter? What brand was it?
neil68
February 02, 2013, 04:18:28 am »
Quote from: wolfswest on February 01, 2013, 13:38:26 pm
I've been using an original Mohr Performance mid-mount for just over seven years in my street/strip Beetle:
http://www.mohrprf.com/products.htm
. It was a straight forward bolt-on installation...here's a picture:
It has been installed for over 500 quartermile drag races on two different tranaxles (different gear ratios) without any issues. I also have a Berg engine support bar installed. I'm a terrible driver, so the Beetle launches can be pretty sketchy sometimes, but I think the mid-mount has no doubt helped prevent nose cone or front mount issues
Last Edit: February 02, 2013, 23:19:42 pm by neil68
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
fish
February 02, 2013, 06:02:26 am »
So it's actually not tied into the frame horns but prevents torque twist acting as a counter lever?
February 03, 2013, 02:22:50 am »
Here is a mount I make, Its meant to have a peice welding to flange on frame horns to make wider. I had pan painted and tranny installed before I started to make them. Next time trans comes out will weld peices in and bolt rubber mounts through. Hope this helps in some way
February 03, 2013, 02:29:11 am »
Another style I make
February 03, 2013, 02:34:57 am »
Peice that I weld to flange on pan.
guillaume
February 05, 2013, 16:30:29 pm »
I have installed the Danny's Gab Fab mid mount on my pan. The quality is top notch and after welding the small flanges and drill them, it fits perfectly.
The design is very nice too
