October 14, 2026, 19:41:33 pm
| | |-+  fan belt for t1 porsche shroud
Author Topic: fan belt for t1 porsche shroud  (Read 5600 times)
Black_65
« on: February 12, 2013, 17:46:32 pm »
Hi Guy's
I've got a T1 Porsche shroud coming from the states that i got at a great price with only a little 'fibre glass' repair and paint.
Now i need some help on sorting out a 'fan belt' for the set up...:confused:
I'm planning to use a POWER PULLEY on my 2165 with the top pulley on the fan. Now im ethier going to use a,
- scat power pulley
- jaycee 6" power pulley
-reichspeed aircooled
Any help? here's a few pictures of the fan i have Cheesy
Thanks Smiley
gizago
« Reply #1 on: February 12, 2013, 18:37:58 pm »
Fit it and measure it would be the best bet.
andy198712
« Reply #2 on: February 12, 2013, 20:45:47 pm »
yeah i know its not the easiest way but probably best, i had the same issue with a smaller pulley on mine.
are you home to measure it or still on deployment?
(loving the porka fan btw)
« Reply #3 on: February 13, 2013, 09:55:34 am »
First and foremost you should tackle the issues that it only cools one side of your engine.
Black_65
« Reply #4 on: February 14, 2013, 10:09:24 am »
wooo, dont like the sound of that! what do you mean?
Erlend / bug66
Global Moderator
SCC Event
« Reply #5 on: February 14, 2013, 10:25:00 am »
The fan will blow all (almost) of the air over to one side, because of the turbulence the fan makes. Since there is no vanes inside the shroud, one side will be cooler than the other. Rev it up and feel under both cylinders at the same time. There will be a difference.
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
« Reply #6 on: February 14, 2013, 10:27:39 am »
If you look closely on the new fan houses made by CSP and also take a look at what Pauter did to his fan house you will see what I`m trying to tell you: http://pauter.com/Ghia.htm On the new fan houses they have changed the design so that it guides the air evenly to all the cylinders instead of only #1 and #2 as yours will do. A simple test, use tape and seal the fan house then spin the fan around with a drill and feel the airflow from the plug holes.
-BB-
andy198712
« Reply #7 on: February 14, 2013, 11:47:28 am »
or sell it to me Wink
