September 23, 2026, 10:25:40 am
| | |-+  Stepped Headers
Author Topic: Stepped Headers  (Read 8300 times)
« on: July 05, 2007, 19:42:30 pm »
Anyone ever run a stepped header on a flat four? I was checking out headers and ran across one on aircooled.net which is stepped from 1 5/8 to 1 3/4. Its built by A1. I wonder how this would work on the 2276 I am planning for the '67. Anyone ever have any experience with this type of header?
Thanks,
John Rayburn
« Reply #1 on: July 06, 2007, 02:22:46 am »
Jim Kurlinski switched his out to one and said he didn't notice a change....
I also park at Nick's.
deano
« Reply #2 on: July 06, 2007, 04:10:17 am »
We tested one from A-1 Mufflers on our 2332cc nitrous engine. Made good power, so I am going to use that system (1-5/8 to 1-3/4) on my '67's 2276.
Anglia Obsolete Guru
'67 Heaven
« Reply #3 on: July 06, 2007, 13:12:44 pm »
It sounds like an interesting concept. I will get in touch with A-1 when I am a bit closer to buying the engine parts. Your return will probably depend on the engine combo and state of tune.
Hey Deano, is that the blueprinting motor? Did you make any other changes after the series was printed to it? I always wondered if you would change the formula with some of the new technology that has been introduced in the almost 10 years (has it actually been that long) since the series started.
deano
« Reply #4 on: July 06, 2007, 17:56:14 pm »
Yes, same blueprinted engine that was in HVWs, and that was in the Race Shop Ghia as well. Probably not, other than repainting the tin, since the car is orange and not yellow. Unless I can figure out a clean way to install a vacuum pump.
'67 Heaven
