September 26, 2026, 11:57:55 am
| |-+  For sale!
| | |-+  MSD Items, Turbo Items !!!
Author Topic: MSD Items, Turbo Items !!!  (Read 2911 times)
Daz C
« on: March 07, 2013, 20:07:49 pm »
Custom made draw through turbo manifold, to suit Holley carb/4" turbo inlet, brand new & great quality, £140 + post.
http://i191.photobucket.com/albums/z259/Daz67/025_zps6853b41d.jpg
Billet/Stainless JDM 38mm wastegate with 5>15psi springs, also fully adjustable, Dyno runs only, £70 + post.
http://i191.photobucket.com/albums/z259/Daz67/029_zps3935bace.jpg
MSD Blaster2 coil, good as new, £30 + post.
http://i191.photobucket.com/albums/z259/Daz67/021_zps8cb9d0f5.jpg
MSD Rpm Window switch, use to activate NOS systems, shift light etc, £35 + post.
http://i191.photobucket.com/albums/z259/Daz67/020_zps063878b5.jpg
MSD soft touch Rpm limiter, uses normal MSD Rpm chips to set limit, can be used on 009, Petronix, Mallory etc as well as MSD systems, easy to wire up, £70 + post.
http://i191.photobucket.com/albums/z259/Daz67/019_zpsd8e00b81.jpg
MSD 6BTM, Same as normal 6AL but with added boost retard facility, Fully adjustable, ideal for you draw-thru turbo guys, way better than locking timing out, £375new, asking £175 + post.
http://i191.photobucket.com/albums/z259/Daz67/017_zps54e2d25c.jpg
MSD start retard module, ideal for you draw-thru turbo guys who lock out your timing, £70 + post.
http://i191.photobucket.com/albums/z259/Daz67/015_zpsce33db70.jpg
Custom made ali Comp Elim/SuperFlow turbo manifolds, 2"od where they join center section, fantastic quality, £125 + post, cost 2x that .
http://i191.photobucket.com/albums/z259/Daz67/008_zpsda46262e.jpg
http://i191.photobucket.com/albums/z259/Daz67/013_zpsbd17f0fc.jpg
More items to follow over next few days ie; Eboost2 system !!!!! etc
Daz,
01609 777459
