October 14, 2026, 17:00:33 pm
2442cc Turbo Drag Race Motor
Topic: 2442cc Turbo Drag Race Motor (Read 5784 times)
notchdrag
March 07, 2013, 21:04:53 pm »
2442cc Turbo drag race motor, new engine never started Curious Dreamer and thank you to refrain
Case :--------------------------Autocraft Pro Series Case
Crank : ------------------------Scat 88mm Pro-Drag, Forged Flanged 8 Bolts, Type 4 mains, 2-inch Chevy journals
Rods : -------------------------Pauter, 6 inch
Rod bearing ; ----------------Clevite Calico Coating
Pistons : -----------------------CP piston
Cylinders : --------------------Autocraft 94mm Billet
Oil Pump : ---------------------Autocraft, billet aluminium, Stage 3 Dry Sump.
Oil Filter : ---------------------Jaycee Billet mount w/adjustable Bypass valve,
Systeme One filter
Cam : ---------------------------Billet 9130 Flat Tapped Cam 318hl/ 282@.050 lift .430 x
1.7=731. with 112 lb centers. Heads Up Performance
Cam gear : ---------------------Magnum
Cam Followers : --------------JayCee TS-2 Tool Stell Lifters
Pushrod : -----------------------Autocraft
Rocker Arms : -----------------CD Roller Rocker Arm Assemblies 1.7
Pushrod tubes : -----------------Pauter
Heads : --------------------------Component Developement by Roger
Crawford Heads Up Performance.
Valves : -------------------------Titane 50 x 40
Valves Spring : -----------------K-Motion , Titanium spring retainers
Compression : ------------------8.5:1
Ignition : ------------------------Low profile distributor to use with MSD crank trigger
ignitions with a large 5" cap with widely spaced terminals,
MSD Programmable Digital 7
Induction : ----------------------Modified 750cfm Demon 4-barel carb, CT4 70mm
T4SB/BB Comp Turbo, E-Boost 2.
Exhaust Systeme: --------------Custom by Tonys and coating
Flyweel : ------------------------RLR for Revolution 6 Clutch
Cluch : ------------------------- RLR Revolution 6 Clutch System double disc
Vacuum Pump and Alternator Kits : ------------------------------GeerS
notchdrag
Re: 2442cc Turbo Drag Race Motor
March 08, 2013, 12:01:11 pm »
look
www.notchdrag.blogspot.com
notchdrag
March 10, 2013, 20:10:12 pm »
look
Green Goblin
March 11, 2013, 20:35:05 pm »
Hi,
I sent you a PM also, How much are you looking for?
Andy
www.DKRclub.co.uk
notchdrag
March 14, 2013, 20:03:39 pm »
notchdrag
March 23, 2013, 11:21:58 am »
up
notchdrag
April 14, 2013, 18:58:51 pm »
up
