August 13, 2026, 00:50:33 am
| |-+  For sale!
| | |-+  2442cc Turbo Drag Race Motor
Author Topic: 2442cc Turbo Drag Race Motor  (Read 5642 times)
notchdrag
« on: March 07, 2013, 21:04:53 pm »
2442cc Turbo drag race motor, new engine never started Curious Dreamer and thank you to refrain
•   Case :--------------------------Autocraft Pro Series Case
•   Crank : ------------------------Scat 88mm Pro-Drag, Forged Flanged 8 Bolts, Type 4 mains, 2-inch Chevy journals
•   Rods : -------------------------Pauter, 6 inch
                 Rod bearing ; ----------------Clevite Calico Coating
•   Pistons : -----------------------CP piston
•   Cylinders : --------------------Autocraft 94mm Billet
•   Oil Pump : ---------------------Autocraft, billet aluminium, Stage 3 Dry Sump.
•   Oil Filter : ---------------------Jaycee Billet mount w/adjustable Bypass valve,
                                                   Systeme One filter
•   Cam : ---------------------------Billet 9130 Flat Tapped Cam 318hl/ 282@.050 lift .430 x
                                              1.7=731. with 112 lb centers. Heads Up Performance
•   Cam gear : ---------------------Magnum
•   Cam Followers : --------------JayCee TS-2 Tool Stell Lifters
•   Pushrod : -----------------------Autocraft
•   Rocker Arms : -----------------CD Roller Rocker Arm Assemblies  1.7
•   Pushrod tubes : -----------------Pauter
•   Heads : --------------------------Component Developement by Roger
                                                Crawford Heads Up Performance.
•   Valves : -------------------------Titane 50 x 40
•   Valves Spring : -----------------K-Motion , Titanium spring retainers
•   Compression : ------------------8.5:1
•   Ignition : ------------------------Low profile distributor to use with MSD crank trigger
                                              ignitions with a large 5" cap with widely spaced terminals,
                                              MSD Programmable Digital 7
•   Induction : ----------------------Modified 750cfm Demon 4-barel carb, CT4 70mm
                                               T4SB/BB  Comp Turbo, E-Boost 2.
                 Exhaust Systeme: --------------Custom by Tony’s and coating
•   Flyweel : ------------------------RLR for Revolution 6 Clutch
•   Cluch : ------------------------- RLR Revolution 6 Clutch System double disc
•   Vacuum Pump and Alternator Kits : ------------------------------GeerS
notchdrag
« Reply #1 on: March 08, 2013, 12:01:11 pm »
look www.notchdrag.blogspot.com
notchdrag
« Reply #2 on: March 10, 2013, 20:10:12 pm »
look
Green Goblin
« Reply #3 on: March 11, 2013, 20:35:05 pm »
Hi,
I sent you a PM also, How much are you looking for?
Andy
notchdrag
« Reply #4 on: March 14, 2013, 20:03:39 pm »
 Shocked Shocked Shocked
notchdrag
« Reply #5 on: March 23, 2013, 11:21:58 am »
up
notchdrag
« Reply #6 on: April 14, 2013, 18:58:51 pm »
up
