September 24, 2026, 21:53:49 pm
Performance engine and parts
Topic: Performance engine and parts (Read 3663 times)
samba66
March 13, 2013, 22:15:26 pm »
All parts can be delivered to Volksworld show
2017CC Type 1 engine
78.4mm Scat crank
90.5mm Mahle barrels and pistons
Lightened flywheel
New case when built AS21 drilled and tapped for full flow
Kennedy 1700lb Pressure plate and heavy duty disc
040 heads 40 x 35.5 valves ported and polished
Chromoly pushrods Scat tubes
Gene Berg pulley, linkage, oil filler breather, gland nuts, manifolds
Twin Weber 40IDF carbs
Engle 125 cam, bolt up rockers
Powder coated tinware
Deep sump
Merged stainless 1 5/8 Turbo Thomas header
VW Speedshop large muffler has slight scraping from being in lowered car.
Bosch 009 with petronix
12v Bosch alternator
Facet fuel pump and regulator
External oil cooler braided hoses and filter head.
Engine was built by Nigel Allen VW services and installed in show car engine has only done 1500 miles and is fully complete to bolt in and go, really nice cruiser and quick. £2750
Pair weber 48IDA's brand new bench run only by Matt Keene@Airkraft manifolds, linkage, original stacks and big stacks £800
Engle FK8 cam brand new clearanced for stroker £50
SSP Chromed 5 spokes wide 5 brand new still in boxes with bolts £375
Brasilia fan housing powder coated black £75
kev d
Re: Performance engine and parts
March 13, 2013, 22:56:36 pm »
Hi mate,
Does the fanshroud have outlets for the heat exchangers?
If so Ill have it.
Kev
samba66
March 13, 2013, 23:33:09 pm »
No heater outlets.
kev d
March 13, 2013, 23:54:10 pm »
Ok thanks
Cars without heating in Aberdeen arn't much fun...
jonathan
March 14, 2013, 06:28:02 am »
PM sent.
