November 02, 2026, 17:11:18 pm
| | |-+  MeXXspeed Racing mill
Pages: 1 [2] Print
Author Topic: MeXXspeed Racing mill  (Read 62216 times)
MeXX
« Reply #30 on: September 08, 2013, 08:35:29 am »
Hi
Here are some updates:
As after a broken crank I had to wait for replacement; I made some minor changes.
"Luckily" the crank broke during the burnout and I was able to feel that something was going wrong switching off the engine and saving allot of other parts.
MeXX
« Last Edit: September 08, 2013, 08:39:35 am by MeXX » Logged
Drag or Die
MeXX
« Reply #31 on: September 08, 2013, 09:00:41 am »
As I wanted to raise the compression ratio from 12.2 to 13.8 it was necessary to machine valve pockets into the pistons.
Modeling clay was use to see the "finger print" of the valves:
By cutting the clay you can see the clearance between valves and piston:
2.5mm deep pockets were machine:
MeXX
Drag or Die
MeXX
« Reply #32 on: September 08, 2013, 09:14:45 am »
The valve springs K-Motion K1100 were changed to state of the art micro polished PSI springs.
The K-Motion titanium retainers were changed to Del West tool spring retainers.
The K-Motion steel locks were changed to Del West titanium locks.
Check out how thin the new tool steel retainers are  Shocked
MeXX
Drag or Die
MeXX
« Reply #33 on: September 08, 2013, 09:25:05 am »
Thanks to Thorsten Pieper I was able to test his new tool steel lifters.
They weight only 56g and need no fancy break in procedures so you can change the cam without changing the lifters.
thanx Thorsten
MeXX
« Last Edit: September 18, 2013, 07:06:07 am by MeXX » Logged
Drag or Die
Type1/DVK
« Reply #34 on: September 08, 2013, 16:45:52 pm »
thanks for sharing all your info and pictures, really nice to be involved!  Grin Cheesy
Shag55
Shag Leone, SL-1racing
« Reply #35 on: September 08, 2013, 23:36:47 pm »
Those retainers are nice! Top guys are now using mostly the tool steels.
I thought you were roller set up on this motor? Or are the TPs for a back up motor?
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
Fasterbrit
« Reply #36 on: September 12, 2013, 08:17:15 am »
Mexx... Have to say your engine is a work of art! It really is beautiful. Shame about the crank breakage. Any ideas as to why it broke? Does the grain structure of the material give any clues?
Regards, Matt
www.air-kraft.com
www.marcomansiperformance.com
MeXX
« Reply #37 on: September 18, 2013, 07:09:52 am »
Hi Shag
To keep it easier for the valve train my engine is still flat tappert setup.
But V2 season 2014 will be a roller setup.
MeXX
Drag or Die
Shag55
« Reply #38 on: September 18, 2013, 18:46:00 pm »
Are you using a chilled iron or steel billet cam?
MeXX
« Reply #39 on: September 18, 2013, 19:59:18 pm »
Hi Shag
I'm runnin' a chilled iron engle FK 47 that you can buy everywhere, combined with Thorsten Pieper Tool Steel Lifters.
MeXX
Drag or Die
kraftkaefer
« Reply #40 on: September 27, 2013, 05:24:41 am »
Hallo MeXX,
hab Dir eine PN geschickt.
Gruß Stefan
« Last Edit: September 27, 2013, 05:27:06 am by kraftkaefer » Logged
www.kraftkaefer.de
FULLA GROFFD Drag Racing
Typ3racing
« Reply #41 on: October 04, 2013, 19:29:24 pm »
Bad Idea.
So everytime the NOS kicks in the fatal result is another meltdown.
Jonny Grigg
« Reply #42 on: October 05, 2013, 09:41:41 am »
Bad Idea.
Dependant on the amount of N2O/fuel and ignition retard, of course.
MeXX, how much retard do you dial on the gas? Also what "shot" are you putting in it? My motor has a 14:1 compression and nitrous, so am interested to know how you are approaching the same point- high compression and gas.
Thanks,
Jonny
No Compromise. O/FF111
Jonny Grigg
« Reply #43 on: October 05, 2013, 09:42:32 am »
Should mention I am using VP C23 fuel too  Wink
« Reply #44 on: October 28, 2013, 16:29:30 pm »
<a href="http://www.youtube.com/v/K-I3pdEiq0I" target="_blank">http://www.youtube.com/v/K-I3pdEiq0I</a>  Wink
« Reply #45 on: October 28, 2013, 17:17:43 pm »
Bad Idea.
I believe the cam choice will have something to say. Mexx is using a FK47 which is a cam that will build cylinder pressure quite low down where the nitrous is most effiecent. In other words, it is cruicial that he control the ignition and fuel. I used a small nitrous shot with a FK46 and did not retard the ignition. It was ok up to 70ish hp. I later changed to a FK89 and (did not change the CR) and never experienced any issues no matter what. Roar (N2O) here on The Lounge used a 135 shot with his 12.8 CR engine.
-BB-
russ fellows
« Reply #46 on: October 30, 2013, 20:26:01 pm »
I broke my moldex one at 8000 revs on full boost in the same place. Which one are you replacing it with
spoolin70
« Reply #47 on: November 01, 2013, 18:41:10 pm »
Hi Mexx
Did you make your own Ti headstuds ?
If you didn't can I ask where they came from.
I'm in desperate need for some strong studs.
Darren
Shag55
« Reply #48 on: November 01, 2013, 18:47:39 pm »
Race ware studs are the strongest. ARP or Bugpack are also pretty strong. Tai must be an expansion thing?
spoolin70
« Reply #49 on: November 01, 2013, 21:38:42 pm »
Thanks for the info Shag.
LNengineering don't sell the air-cooled ARP kit any longer.
ARP directly don't stock/make it and want $1000 to $1600 to make a set.
Raceware are out of stock, 2-3 months wait for the next batch.
Pierside is next, hoping they have some raceware in stock.
Although I am curious about Ti studs and how they expand with heat.
Mexx. Some of your work, especially page 1 would not look out of place in an art gallery. Exceptional work !
Darren
MeXX
« Reply #50 on: July 09, 2014, 09:23:31 am »
Hi
As there are no races the next few weeks I found time to post the 2014 upgrades.
The new mill is V1.2 its basically the old engine with flat tappert FK 47 cam & Thorsten Pieper Tool Steel lifters
but with new 7-bolt Billet Cylinder housings and new Billet Heads.
Heads ready 4 assembly
to keep the interference between barrel and cylinderhousings right they were measured on a Zeiss Duramax
Zeiss Duramax screenshot
7th stud closeup
So long MeXX
« Last Edit: July 09, 2014, 10:31:01 am by MeXX » Logged
Drag or Die
MeXX
« Reply #51 on: July 09, 2014, 09:37:11 am »
Cylinder ready for honing
three step honing on a sunnen hone machine
honing finished
Drag or Die
MeXX
« Reply #52 on: July 09, 2014, 09:51:41 am »
Thanx to CP-Carrillo I got shorter rod bolts so notching the barrels is not necessary anymore.
new short bolt vs old traditional design
Rods an pistons assembled
Cylinder assembled
MeXX
« Last Edit: July 09, 2014, 19:09:36 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #53 on: July 09, 2014, 10:11:42 am »
Springs are Isky Tool Room with Xceldyne Titanium retainers
Titanium valves from Del West and Xceldyne
Beryllium bronze valve shims
Valve locks are Del West titanium
Del West lash caps
Drag or Die
Andy Sykes
« Reply #54 on: July 09, 2014, 11:55:56 am »
amazing work love it  Smiley
MeXX
« Reply #55 on: July 09, 2014, 12:25:25 pm »
Drag or Die
« Reply #56 on: July 09, 2014, 14:57:10 pm »
Beautiful
Pages: 1 [2] Print
