August 11, 2026, 22:24:43 pm
| | |-+  MeXXspeed Racing mill
Author Topic: MeXXspeed Racing mill  (Read 58814 times)
MeXX
« on: March 19, 2013, 09:03:47 am »
As the drag racing season 2013 is starting soon,
I just rebuilt my race engine,
here are some pix:
Rod bearings were changed from Chevy CB610P to Buick CB745P
In order to use the CB745P you have to narrow and champfer it slightly
The Chevy CB610P
You can see the gained bearing surface of the CB745P
MeXX
« Last Edit: March 19, 2013, 09:26:18 am by MeXX » Logged
Drag or Die
MeXX
« Reply #1 on: March 19, 2013, 09:11:05 am »
New billet seamees cylinders were milled
fins were milled
liners installed
notches for the main bolts
MeXX
Drag or Die
MeXX
« Reply #2 on: March 19, 2013, 09:18:55 am »
chambers were modified slightly
seamees beryllium valve seats got a fresh 3- angle valve job
Mainley valves installed 2.10" inlet and 1.625" exhaust
K-motion K1100 springs were set to 2.00 installations height
MeXX
« Last Edit: March 19, 2013, 09:24:40 am by MeXX » Logged
Drag or Die
MeXX
« Reply #3 on: March 19, 2013, 09:32:58 am »
Parts ready for assembly
Titanium head studs installed
Scat 90mm crank Pauter 6.0 Chevy rods.
Rod bearings CB745P were coated
MeXX
Drag or Die
MeXX
« Reply #4 on: March 19, 2013, 09:42:08 am »
The pin for the first main bearing didn't fit the bearing and had to be modified (otherwise it would be a short season)
As I don't thrust these crappy hardware washers and bolts I have modified the cam gear for ARP PRO bolts
Crank installed, coated lifters installed
Cam lube applied to the lifters, coated cam bearings installed
MeXX
« Last Edit: March 19, 2013, 09:43:43 am by MeXX » Logged
Drag or Die
MeXX
« Reply #5 on: March 19, 2013, 09:54:23 am »
The cylinders were diamant honed to 800 grid
Total Seal Quick seal was applied and for assembly Tolal Seal Assemly lube was used
Pistons are custom CP X box design and got fresh coating
Wrist pins are CP 9310 with .20 wall, Del West 9310 .15 wall DLC coated (99g)  and PPP Titanium DLC coated with steel wear caps (75g) which I used
MeXX
« Last Edit: March 20, 2013, 09:06:05 am by MeXX » Logged
Drag or Die
MeXX
« Reply #6 on: March 19, 2013, 10:04:25 am »
Pistons installed
Slipper skirt close up
Heads ready for assembly
Long block assembly finished.
MeXX
Drag or Die
MeXX
« Reply #7 on: March 19, 2013, 10:13:59 am »
Front cover and oil pump parts
Oil pump is a modified 38mm Revmaster with integrated oil pressure regulator
New bigger oil sump (8 liter), suction line is #12
If can be opened for cleaning, the top cover got window mill for reducing weight
MeXX
« Last Edit: March 19, 2013, 10:16:18 am by MeXX » Logged
Drag or Die
MeXX
« Reply #8 on: March 19, 2013, 10:23:40 am »
All this and you use a FK47?
As of the 90mm stroke I wanted to keep the PRM relatively low and the FK 47 with 1.5 rockers resulting in .628 lift and 278° @ .050
makes over 300 HP below 7000 possible and is easy on the parts.
PS. V2.0 is under construction already  Grin Grin Grin
MeXX
Drag or Die
MeXX
« Reply #9 on: March 19, 2013, 10:30:27 am »
Front cover and oil sump installed
Oil sump with #12 Goodridge suction line
suction line close up
Bracket helps to carry the weight of the sump
MeXX
« Last Edit: March 19, 2013, 10:32:27 am by MeXX » Logged
Drag or Die
« Reply #10 on: March 19, 2013, 10:30:54 am »
MeXX
A FK47 is never easy on the parts but I see your points.
Looking good!
MeXX
« Reply #11 on: March 19, 2013, 10:35:04 am »
MeXX
Looking good!
It's always a tough live for parts in a racing mill, but it can even get tougher.......
MeXX
Drag or Die
MeXX
« Reply #12 on: March 19, 2013, 10:45:20 am »
Jesel MoHawk 1.5 Rockers installed on the right side
Jesel MoHawk 1.5 Rockers installed on the left side
Sheet metal valve cover in place.
maximum contact surface of the billet cylinders resulting in minimum clearances of the main bolt nuts.
MeXX
« Last Edit: March 19, 2013, 11:28:42 am by MeXX » Logged
Drag or Die
MeXX
« Reply #13 on: March 19, 2013, 10:52:15 am »
mission completed
58mm super sucker
deep throat  Grin
MeXX
Drag or Die
karl h
« Reply #14 on: March 19, 2013, 11:14:21 am »
are you home friday afternoon?
Basti
« Reply #15 on: March 19, 2013, 11:53:09 am »
This is pure engine porn!!!
- black 62 cal look beetle
- Pro Mod Race car
mychatype3
« Reply #16 on: March 19, 2013, 14:35:55 pm »
+1 just wet my self  Grin
1968 fastback "in resto"
Ragtop
8.93 at SCC 2012
« Reply #17 on: March 19, 2013, 15:53:19 pm »
The attention to detail and your craftmanship is over the top!!
Shag55
Shag Leone, SL-1racing
« Reply #18 on: March 19, 2013, 17:57:29 pm »
Beautiful stuff Mexx!
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
Wout
« Reply #19 on: March 19, 2013, 19:09:12 pm »
Art!!!
gr
Wout
Aircooled vw's for life!
lecid
« Reply #20 on: March 19, 2013, 20:13:42 pm »
Just waouwwwww  Shocked Shocked Shocked
RedMamba Racing
Andy Sykes
« Reply #21 on: March 19, 2013, 21:13:42 pm »
Just awesome Smiley
« Reply #22 on: March 19, 2013, 21:52:17 pm »
Your stuff is beautiful
How do you thing this bolt pattern compares?Huh?
« Last Edit: March 19, 2013, 21:55:06 pm by Fiatdude » Logged
58vw
« Reply #23 on: March 21, 2013, 05:47:33 am »
disgusting mexx!!! Grin
www.4inbore.com
Angleflows...order them now
ibg
« Reply #24 on: March 21, 2013, 11:21:41 am »
Mexx, beautiful work, a question? what is the press fit of the liners in the siamese fins, as it 'looks' like the liner makes the seal at the head and the fins make the seal at the case, or is the liner stepped at the case end.
MeXX
« Reply #25 on: March 21, 2013, 11:32:23 am »
Hi
The interference between the liner and the seamees cylinder is .03 mm there is a step of 1mm on the head side, if it was on the case side there would be very little material between the liners forcing them to get out of round. Because of the little interference it is possible to change the liners easily by heating up the cylinders.
MeXX
« Last Edit: March 21, 2013, 12:17:47 pm by MeXX » Logged
Drag or Die
« Reply #26 on: March 21, 2013, 13:37:56 pm »
amazing engine!
did you coat your self? which coating went on the lifters? was it just the faces or the sides too?
not tempted to get your springs DFL coated also?
MeXX
« Reply #27 on: March 21, 2013, 20:56:23 pm »
amazing engine!
Hi Andy
Yep coating is done by myself ;
It's DFL; and its only on bearing, pistons skirts and oil pump housing.
On lifters face and cam lobes for break in only, because it doesn't last for very long.
On the springs it makes no sens for me because I would never ever sand blast springs so it won't last long enough.
But for the future I will use micro polished PSI springs (awesome stuff).
So hey keep on coatin' ...... Grin
MeXX
Drag or Die
Type1/DVK
« Reply #28 on: March 22, 2013, 00:25:54 am »
thanks for sharing this amazing project and pictures!  Grin
« Reply #29 on: March 22, 2013, 01:23:01 am »
amazing engine!
Hi Andy
MeXX
Hi MeXX
Cool I've dabbled in DFL too, do you blast your cam and lifters first as well yeah? I was thinking about that... Encase it would effect the hardening or something? Would have thought the sides would be good to do?
Techline said you don't need to blast them, just soak in acetone but I tried this on some used doubles and it didn't bond well...
I've done all sorts for my build, drysump pump case and gears, bearings, crankshaft, rocker shafts, feet and cups, cam gears ect...
They make a coating for barrels that you buff on too....
Wether it makes a differance who knows but I think it will Smiley tests back that up too so must be something in it.
Enjoying seeing this build, great to see the level of detail in it!
Andy
