November 02, 2026, 15:15:38 pm
| | |-+  96.5mm P&C kit? Any other options than Autocraft?
Author Topic: 96.5mm P&C kit? Any other options than Autocraft?  (Read 5301 times)
930
« on: March 22, 2013, 07:22:07 am »
Are there any other viable options apart from what Autocraft offers for 96.5mm P&C's? The case is an Autocraft pro series 96.5mm (obviously) case.
If I can find good cylinders then I can go with J&E, Wiseco or such pistons or a complete kit is an option as well.
The car is essentially a street car so the bigger the cooling fins are the better it is...
(addition: as per Autocraft they don't recommend changing the bolt pattern as the heat from welding might distort the case...just in case if someone would suggest changing the stud pattern to get a bigger bore cylinders Wink )
Thanks in advance!
edit: OK just realized this might fitter better to cal-look section as it's a street car. Mods can move this if seen fit.
« Last Edit: March 22, 2013, 14:35:49 pm by 930 » Logged
« Reply #1 on: March 22, 2013, 18:28:47 pm »
I think autocraft cylinders have good fins and JE pistons also ...
« Reply #2 on: March 23, 2013, 22:56:33 pm »
I'm certain Autocraft cylinders are good, that's quite clear.
I was trying to find alternatives for these as P&C kit is around US $ 1850 from Autocraft and that's are pretty pricey considering what the pistons alone would cost - even though cheap and good are typically two different products and just a note that I am not trying to find the most inexpensive option available.
If these are the only ones available then I know what I need to buy.
