September 25, 2026, 03:00:17 am
Wheels and finish's
Topic: Wheels and finish's (Read 8359 times)
Wheels and finish's
April 04, 2013, 23:08:34 pm »
After chat'n with mr. Ratto , I though I'd start this thread. Lets see your wheels and finish's for a kind of reference for when we all restore some wheels. What paint/colors, primer, polishing , lugs , etc..Any tricks that might help everybody out. Here is a shot of some flat-4 wheels I did for my 67. First I machine'd off any emblem, cast into wheel. Had my helper Jorge file down sharp corner's on spokes from original machine work. Then started with 200-600 grit to sand and prep for polish'r. Then masked and prime'd with DTM primer and sprayed very dry to get a rough cast look and then painted semi gloss black useing cheep lacquer thinner instead of reducer to hopefully help get paint to blush . To further the flattening effort in paint.
Last Edit: April 04, 2013, 23:14:03 pm by danny gabbard
Re: Wheels and finish's
April 04, 2013, 23:12:30 pm »
Something I made for when I sent my 5 spokes out to get polished. I did not want polisher to lean into spokes that are a cast finish and mess the finish up. It screw onto the stock cap mounting screw holes
April 04, 2013, 23:46:32 pm »
Quote from: danny gabbard on April 04, 2013, 23:08:34 pm
thanks Danny, I'm looking to augment the changes going on with a different finish on my Flat 4's, this will be fun to follow.
DWL_Puavo
April 05, 2013, 08:22:35 am »
One trick we've used with weary Porsche wheels, is to use ordinary
acidic drain cleaner
(normal stuff to unblock sewer pipes) to
remove anodizing
from the wheel. It's way easier and faster than to remove the anodizing mechanically. Of course the wheel looks hideous after, but it still cuts a great amount of elbow grease.
ibg
April 05, 2013, 11:48:03 am »
Usually drain cleaner is alkaline and made mostly of caustic soda, and yes is will remove anodising quickly. There are similar oven cleaning products.
I prefer to get the anodising stripped at the platers, a bit gentler
Jason Foster
7.69 87mph 12.35 106 mph
April 05, 2013, 13:14:03 pm »
I've used easy off oven cleaner to remove anodizing and if you watch it and be careful it will leave the part spotless. leave it on too long and you get the hideous effect.
April 05, 2013, 17:04:06 pm »
my empi were sandblasted too Danny , and i've added a mat clear coat on them , i like the way she looks on my car
, there's a contrast between my car and wheels , and after removing them due to some cracks on , i've done the same treatment on my torker wheels " (copy of american racing torq trust D 5x205) , and adding a satin clear coat on them too
,at the beginning , my idea was to have a magnesium finish , but those are aluminium , so they're weren't oxyded , and i like them on my car , but there isn't no contrast between my car and wheels
they look the same , but last week i've painted them in dark grey to have a magnesium finish , and i like them , now next step will be put back the wheels on the car to see the result
April 05, 2013, 17:10:08 pm »
Fabs, I like that grey "magnesium" color in the last photo, similar to what I am thinking for my Flat 4's
April 05, 2013, 17:14:24 pm »
Quote from: Jim Ratto on April 05, 2013, 17:10:08 pm
the last thing i would like to do on my wheels would be an oxydation look like the real magnesium wheels , but i don't know how to do it
April 05, 2013, 17:20:14 pm »
A chemical I use to clean alum before welding, Works good for just cleaning wheels. I get it at my local welding supply store, Automotive paint stores carry something like it called aluma-prep
Last Edit: April 05, 2013, 17:23:43 pm by danny gabbard
April 05, 2013, 17:30:23 pm »
A set of 4-3/4 and 5-3/4 riviera's I restored and the same paint treatment I did to a set on my squareback I drove in highschool in about 1980-1
April 07, 2013, 19:55:51 pm »
i've just painting my empi 5 to try some tricks to have an aspect to oxidize
what do think with the colorof wheels with the color of my car ?? more contrast then before
April 07, 2013, 20:11:24 pm »
LOVING THIS THREAD
