September 23, 2026, 01:38:43 am
| | |-+  1700cc + 48IDA
Author Topic: 1700cc + 48IDA  (Read 9806 times)
maX cal-look
« on: April 08, 2013, 08:44:06 am »
Hie Guys !
I Build a 1700cc 'Back In The Day' Motor.
88mm pistons kit machining
Engle 120 + rockets 1,25
Flywheels weighed 200mm, damper
ported and polished heads 40 x 35.5
high compression 9,4:1
Manifolds DDS linkage DDS
Asking for 48IDA : What put in Huh
Ventury (37mm) ?
Idle Jet Holder (120) ?
Emulsion Tube Holder ?
Thank's for your help, that's for a 67 bettle with 8X33 gear-box and 185x80 15p
blue bullet
« Reply #1 on: April 08, 2013, 09:33:14 am »
hi
37 en buses semble un bon comprimis souplesse/perfo
F7 en tubes et je partirais sur du 150 fuel/170air comme base .
J'ai des buses en 37 si tu en cherches ... des bologna pure cal look !!
maX cal-look
« Reply #2 on: April 08, 2013, 10:22:27 am »
Salut,
Pour les buses j'ai déjà, pour le reste je regarde ce soir ! Merci mon poulet pour tes infos !
Hie,
For Ventury I got it, for another parts I will see tonight ! Thank's my Chicken for infos !
maX cal-look
« Reply #3 on: April 08, 2013, 20:01:24 pm »
So, I don't need another help, everybody think like blue bullet Huh
BTW, I find paper :
F7 = Ok !
120 air
135 fuel
So I will change !  Grin
« Reply #4 on: April 08, 2013, 20:09:41 pm »
Hie Guys !
Ventury (37mm) ?
hard to perfect carb tuning on internet, what you read here can be way off in real world. I'd start with 135 main jet, F2 emulsion tube, 60 fuel idle jet and 180 air corrector and make sure your float levels are exactly as Weber lists in their manual
BABOON
SCC Official
« Reply #5 on: April 09, 2013, 07:35:49 am »
I recently dynoed my engine with some of the same specs as yours. This is what I ended up with.
88 p/c
w-120 with 1.1 rockers
10,0 comp
Original heads with 35/32 home ported
1 5/8 merged header with duals
48 IDA with short manifolds
37 venturies
65 idle
F7 with 145 main and 160 air
Made a whopping 97 hp with belt and 105 hp without.
fish
« Reply #6 on: April 09, 2013, 12:09:44 pm »
IDAs on stock valves.......interesting
maX cal-look
« Reply #7 on: April 09, 2013, 19:49:41 pm »
Thank's Guys for your shares !
I will see it ASAP ad tell you the end  Grin
100hp makes me happy BABOON  Wink
deano
« Reply #8 on: April 10, 2013, 03:17:04 am »
Seems to me I used to run 145 mains, and 160 airs with 37mm venturi (110cam, 9.0, 40mm x stock exhaust, 1-1/2 headers.). Drove it for years on the street.
Anglia Obsolete Guru
'67 Heaven
BABOON
SCC Official
« Reply #9 on: April 10, 2013, 07:46:33 am »
This is the engine. Currently in my 67
70slooker
hello
« Reply #10 on: April 10, 2013, 08:08:14 am »
that engine looks fantastic!!
Zündfolge Car Club
maX cal-look
« Reply #11 on: April 10, 2013, 11:11:13 am »
Yes, beautiful engine you got !  Shocked
Love period parts !
And BTW In the 67  Kiss
« Reply #12 on: April 10, 2013, 18:50:14 pm »
I ran a 1776 with ported stock sized valve heads in the mid 80s.
I use some 34mm venturis to get the throttle response where I wanted it.
deano
« Reply #13 on: April 10, 2013, 22:14:57 pm »
Yes, unless you run a 'hit pile of compression, small chokes would be the way to go. Back in the day, smaller than 37s were just not around...
'67 Heaven
« Reply #14 on: April 10, 2013, 22:40:51 pm »
I would have built this around 1982 or 83.
maX cal-look
« Reply #15 on: April 19, 2013, 19:31:18 pm »
News ....
And more coming soon !
