October 14, 2026, 05:32:51 am
| | |-+  Installed height / JPM small springs / type 4 valves /
Author Topic: Installed height / JPM small springs / type 4 valves /  (Read 12119 times)
-Alex-
« on: April 08, 2013, 09:18:25 am »
I have a sort of problem, maybe.
I am getting Thorsten Piepers billet heads, and they have fixed depth of valve pocket.
-Valves 117mm type 4
-JPM small springs an ti retainers
-Lift  15mm
-Udo's lightweight lifters
-Alu pushrods
Recommended installed height for springs is 41mm, and i have feeling that it will be 1-3mm more without shims with these heads.
1mm shim is ok, but two 1mm or one 2mm shim?
« Reply #1 on: April 08, 2013, 12:31:20 pm »
With all that investment I would make a spring pocket "bucket" insert.
Make it the exact height you wish.
If the spring is not guided diametrically in the bottom, I would integrate that in to the insert.
Sounds good and exciting with those jems to heads! Good luck!
-Alex-
« Reply #2 on: April 08, 2013, 13:19:12 pm »
Hello,
The OD of the pocket is 36mm if i remeber correctly and ID 16,8mm.  JPM vw diameter springs are 32mm OD and 17mm ID.
Do you mean machined bucket insert, just dropping it to place? Steel or 6082 / 7075 aluminum?
« Reply #3 on: April 09, 2013, 02:30:53 am »
Check this out.
Just as an example to visualize what I suggest..
A strong steel bucket that locates the spring with a light pressfit on OD. This prolonges life of your spring too.
From the measures you write, it seems like a good opportunity.
http://www.jegs.com/p/Moroso/Moroso-Valve-Spring-Cups/764349/10002/-1
dragvw2180
« Reply #4 on: April 09, 2013, 03:55:13 am »
You might want to look at some valve spring locators instead . I have used them in the past with good results.
http://www.summitracing.com/search/product-line/manley-valve-spring-cups-and-locators?page=2
« Reply #5 on: April 09, 2013, 12:17:04 pm »
Same thing and optimum is guiding on both outside and inside.
If I have to choose, I would choose outside and main spring guiding.
-Alex-
« Reply #6 on: August 16, 2013, 07:40:46 am »
I think the measurements are ok, i measurer from chamber floor to  valvesping pocket, 70mm on TP billet heads, and then transferred the measurements to cad model.
Just recently i got 48x38 117mm manley valves, jpm ti retainers etc, and measurements gave the installed valve height with these components 41,5mm, so i may need only one shim.  Valveguide boss is 16,8mm, spring id is 17,00-17,1mm
« Reply #7 on: August 16, 2013, 07:51:39 am »
-Lift  15mm
-Alu pushrods
What a strange mix of parts......
-Alex-
« Reply #8 on: August 16, 2013, 18:42:32 pm »
not really.. three of them are from JPM
