August 03, 2026, 06:29:21 am
352252 Posts in 28941 Topics by 6923 Members
| | |-+  Nice street engine?
Pages: 1 [2] Print
Author Topic: Nice street engine?  (Read 25029 times)
« Reply #30 on: January 02, 2014, 20:58:20 pm »
i'll play as well.
i am currently building a street engine for my type 3. so all type3 cooling and tinware and under the lid.
it has a 78 DMS crank (the one i got from Ratto years and years ago) finally being put to good use.
90.5 pistons B's (hence me needing one) the case was machined for 90.5's otherwise it would be 94's without a doubt.
an FK44 with 1.25's if needed i can upgrade it with a new set of pushrods and 1.4's, but i am confident this will work out just fine
a CR of 10 on european 98 octane will hopefully do.
my trusty 42DCNF's on the reworked heads with 40X35 valves (originally los bandits, but reworked at Stevesvwshop)
all machining done in my free time at work and hopefully in the fastback very soon to get the car out and drive!
« Reply #31 on: January 05, 2014, 08:04:48 am »
My current motor in car...
Berg case with all there machine work done
DMS 83mm crank VW journal, custom OS dowel pins done by Mark V. @ Berg's
Eagle 5.5 Rods clearance and polished by Mark V. @ Berg's
Cima/Mahle 94mm P/L, dished by Mark V. @ Berg's
14LB Flywheel-German
Berg Forged Gland Nut
1700 Kennedy W/ Berg Street Disk
Berg 3.5lb steel equalizer pulley
Engle 125 106LC W/1.25's, Chinese rockers on Berg shafts and hardware
Magnum Straight Gears
JC push rod tubes
Berg Push Rods
SL Lifters
Heads by Jeff Denham, 42X37.5, welded oval port, Old style tall CB manifolds
IDA Spanish Webers, gone through by Berg's, Berg profiled shafts, O-Ringed, opened up float bowls, 3rd progressions holes, opened up fuel inlet, JC stacks, JC stainless linkage arms
MSD 6AL Ignition W/MSD Dis.
Berg 3 1/2 qt sump
Berg 26mm oil pump, plugged
Berg full flow pump cover
A-1 1/3/4 Sidewinder header/stainless muffler
« Last Edit: January 05, 2014, 08:07:23 am by DKK Ted » Logged
Iryanu
« Reply #32 on: January 05, 2014, 16:29:17 pm »
Who likes nice "driveable" torque around town? My 205/70 getting punished for their sins, engine spec was in my previous post.
<a href="http://www.youtube.com/v/lMV_yA1KxvU" target="_blank">http://www.youtube.com/v/lMV_yA1KxvU</a>
I know I'm a bad man so save the lectures. Kiss
« Reply #33 on: January 05, 2014, 20:28:23 pm »
That car NEEDS a roof chop, then it would look just like the Mike Lawless Cal-look.com t shirt! My first thought was Lil Snort, then rollcage, then chop it! Ace! Grin
« Reply #34 on: January 05, 2014, 20:41:47 pm »
Well, the Dynomite is rather accurate when calibrated right, so what you see there is about what you have. IŽd say that 170 hp with a W120 cam as a base is pretty nice. The peak torque is higher in the rpm than I would have expected, but the heads obviusly flows well.
Its a tad lean for my taste, but it makes good power there.
dannyboy
« Reply #35 on: January 05, 2014, 20:53:33 pm »
great looking gasser bug  Cool
8.77@156.8mph
O/FF 60
Pages: 1 [2] Print
