October 13, 2026, 01:38:36 am
| | |-+  OEM alt stand with Scat shroud.
Author Topic: OEM alt stand with Scat shroud.  (Read 11332 times)
Taylor
« on: April 20, 2013, 02:11:41 am »
      OK, first let me start by saying that using an OEM shroud is not possible at this time due to how narrow my motor is.  I had a nice Thing shroud but couldn't get my carbs on so I sold it.
      I have a cherry, OEM mag, alternator stand that I am trying to use with OEM backing plates on my motor.  The problem I am facing is that because the Scat shroud has the backing plate holes clocked my alternator does not fit square on the stand.  The stand has the bump on it that corresponds with the indentation on the bottom of the alternator.  I could easily use an aftermarket, aluminum, stand but don't really want to.  Should I file the bump on the stand off or modify the alternator?  Bruce would say to modify the cheaper part, which I may do, and Zach would say to run a generator but I assume someone else has had this problem before.
If pictures would make it easier I can post some up.
Taylor
« Last Edit: April 20, 2013, 02:55:18 am by Taylor » Logged
« Reply #1 on: April 20, 2013, 02:45:14 am »
I'd run a generator! Wink
Taylor
« Reply #2 on: April 20, 2013, 02:56:08 am »
^^^^Fixed^^^^  Wink
neil68
« Reply #3 on: April 20, 2013, 03:12:38 am »
I had a similar problem and decided to "dimple" the OEM doghouse shroud, so that the IDA's would clear...right near the blue banjo fittings:
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Taylor
« Reply #4 on: April 20, 2013, 04:33:26 am »
I wish that was a solution I could have pursued Neil.  I would have had to use a BFH to get the clearance I needed.  The fuel inlet didn't hit the shroud, it was the carb body.
dirk zeyen
« Reply #5 on: April 20, 2013, 09:30:20 am »
<a href="http://www.youtube.com/v/BqQm-19n5wY" target="_blank">http://www.youtube.com/v/BqQm-19n5wY</a>
modified shroud..... Grin
back again!!!
« Reply #6 on: April 20, 2013, 11:13:18 am »
ala salzburg
« Reply #7 on: April 20, 2013, 12:30:05 pm »
I have an OEM stand, refurbed Bosch alternator, and Scat 36 doghouse shroud. I didn't notice the problem you're running into on mine.
I'd just modify the stand if it won't affect integrity.
RhoadsVW
« Reply #8 on: April 20, 2013, 19:15:02 pm »
I have the exact same setup on my car with no issues. Except it's a new Bosch alternator.  Have also installed on many other cars with OEM stands and Scat shrouds.  Dave Rhoads
Der Renwagen Fuhrers
Taylor
« Reply #9 on: April 21, 2013, 00:45:03 am »
Lucky for you guys!!  I'm not so lucky.  With the backing plates being clockedslightly the Bosch alt won't sit down all the way.
Lanny Hussey
« Reply #10 on: April 21, 2013, 01:50:51 am »
I've installed that combo a hundred times over the years, never had a problem. What brand of alt is it? I've never seen one with anything on the underside that would prevent it from sitting correctly. Pix?
Hecker
« Reply #11 on: April 21, 2013, 02:18:40 am »
Just take it over to Walker and ask him to narrow that shroud.....I'm sure he can do it !!!
rick m
« Reply #12 on: April 21, 2013, 07:44:50 am »
I used IDA manifolds that offset the carbs a little more and top fed my IDAs instead of using the banjo's. I could have used the banjo's as I did not have any clearance issues with the SCAT shroud....
Rick M
Rick Mortensen
Driving Hot VWs since 1970
Taylor
« Reply #13 on: April 21, 2013, 10:33:31 am »
Well I fixed it!  I had to elongate the two backing plate holes where they mount to the alternator.  This allowed me to rotate the alternator, clockwise,  so that the bump in the stand would fully engage in the recess on the bottom of my new Bosch alternator.  All I needed to do was counteract the clocking of the fan shrouds anti-clockwise backing plate location.
Also, Rick,   even moving the fuel lines on top wouldn't fix my fan shroud problem.  My motor is pretty narrow.
rick m
« Reply #14 on: April 21, 2013, 17:03:07 pm »
Taylor...running short rods, serious flycut for compression or destroked?  Just curious?
Rick M
Rick Mortensen
Taylor
« Reply #15 on: April 21, 2013, 19:54:30 pm »
It has 1"compression height pistons and is flycut a lot.
« Reply #16 on: April 21, 2013, 20:25:08 pm »
Good to hear you solved the issue!
What compression height does a stroker Cima have?
Taylor
« Reply #17 on: April 21, 2013, 20:39:45 pm »
I think they are 1.340".  This motor is a little over an inch narrower.  I had to cut .600" off of the bottom of both cylinder head tins to get them on the motor.
