May 21, 2026, 02:26:35 am
mvptkfjb
MS 230/4 cylinder heads SOLD
Topic: MS 230/4 cylinder heads SOLD (Read 16744 times)
busgods
May 13, 2013, 08:29:31 am »
JPM MS230/4 cylinder heads (for 101.6mm bore), New. Bare heads in 38x48mm sizing, combustion chamber 38.6cc. No valves, no springs, no retainers. - 1500e PENDING
5 bolt rocker shaft setup for Pauter 1.5:1 rockers availlable at 250e extra cost. (No, not available at this stage separately. Sorry.)
SOLD
Last Edit: September 17, 2015, 07:45:31 am by busgods
drgouk
Re: NEW 88x101.6mm RACE long block parts
May 13, 2013, 11:03:57 am »
Hi, Interested in the jpm heads, are they 38cc chambers? they look bigger? Thanks.
busgods
May 13, 2013, 12:46:01 pm »
38.6cc, measured by a trusty machinist. I could double check that if needed. I'm 99.9% sure that the measurement is correct. Surely the heads still need loads of prep work to make them really work, combustion chamber prep, intake and exhaust port work, valve prep etc.. In current condition they are a good starting point and quality valvetrain components can be picked up to suit whatever the combo in mind.
Last Edit: May 13, 2013, 13:02:02 pm by busgods
Jesse Wens
May 14, 2013, 19:56:02 pm »
can you explain how you were going to do the mounting of the pump to the camshaft?
busgods
May 15, 2013, 07:49:13 am »
Add modified. Less parts, less complicated.
Last Edit: September 17, 2015, 07:46:02 am by busgods
busgods
Re: MS 230/4 cylinder heads, 88mm flange crank, rods
May 27, 2013, 12:41:03 pm »
Parts still for sale. Heads would make a great street choice after a combustion chamber prep. Quesstimate on the head CC should be somewhere around 40-45cc after prep which should suite ethanol use no problem with a suitable cam etc...
busgods
June 24, 2013, 11:01:06 am »
Heads can be delivered to EBI if you let me know early enough...
Before friday I would say.
busgods
August 01, 2013, 10:02:05 am »
Heads can be seen in classic this weekend!
busgods
August 28, 2013, 09:57:46 am »
Final reductions...
UltraOrange67-2443
October 08, 2013, 22:09:17 pm »
PM sent
1967 1200 2920cc EFI
busgods
November 28, 2013, 14:08:15 pm »
Plenty of interest. No buyer yet...
Thanks.
busgods
January 07, 2014, 11:53:53 am »
Hedddsssss...
busgods
March 13, 2014, 12:02:44 pm »
Can arrange them prepped for your specs with springs, valves and portwork for approx 1000e depending on the parts needed...
busgods
April 22, 2014, 13:10:14 pm »
Combo deal now for heads and rocker shafts 2000e
busgods
Re: MS 230/4 cylinder heads SUMMER DEAL!
June 04, 2014, 13:31:57 pm »
Summer deal!!!
busgods
July 27, 2014, 13:18:09 pm »
These still available. Delivery to Tierp or SCC possible.
busgods
January 16, 2015, 14:26:20 pm »
Got Dell West Chevy size Ti retainers and locks to go with these if needed. No extra cost...
busgods
April 07, 2015, 06:53:19 am »
Heads still available, dollar to euro very strong...
busgods
August 03, 2015, 11:06:09 am »
Still on the shelve...
