October 13, 2026, 07:17:59 am
Need stainless screen
Topic: Need stainless screen (Read 5021 times)
May 17, 2013, 04:46:31 am »
I need a source for welded screen and not woven. I have some that the hole size is .218 square and some that is very fine, Would like some that square's are about .125 square. I already tried Mc Master carr. Thanks for any help.
Jason Foster
7.69 87mph 12.35 106 mph
Re: Need stainless screen
May 17, 2013, 05:37:00 am »
Mcmaster does have a special orders division and Grainger does as well
May 17, 2013, 11:43:46 am »
http://www.mscdirect.com/
http://www.fastenal.com/web/home
Fastenal has a lot more stuff than I ever realized, so might be worth checking into.
May 17, 2013, 17:40:37 pm »
http://www.fastenal.com/web/products/raw-materials/sheet-stock-material/wire-cloth/_/Navigation?term=wire+cloth&termca=&termpx=&sortby=webrank&sortdir=descending&searchmode=productSearch&rfqXref=&rfqKeyword=&rfqId=&rfqLineId=&r=~
|categoryl1:"600930 Raw Materials"|~ ~|categoryl2:"608602 Sheet Stock Material"|~ ~|categoryl3:"608689 Wire Cloth"|~ ~|sattr04:^"Stainless Steel"$|~
Unknown, Danny, if this "wire cloth" as it is referred to, is welded or not.
Once you specify 'welded', the opening size choices dimenish greatly ... MSC only lists 'welded' is as fine as 4/inch.
The listing above are the offerings from fastenal.
... I'll make it myself if necessary! LOL
May 17, 2013, 18:23:06 pm »
Thanks for info guys. Looks like what I got is a industry standard and smallest hole dia that is made. Called all the big name guys and was told the same thing. So the .022 will have to work.
Speed-Randy
May 18, 2013, 00:11:06 am »
besides, you only need to keep the big chunks out
. thats what Brinton told me
www.vdubspeedshack.com
May 18, 2013, 02:20:08 am »
Danny, you leaving them open behind the screen? I could see you hammering out some baffles that would let the air in but redirect the rain.
