October 13, 2026, 02:50:28 am
Another sparkplug question...
Topic: Another sparkplug question... (Read 12307 times)
Erlend / bug66
Global Moderator
SCC Event
May 20, 2013, 00:13:07 am »
Hi
Need some pointers..
1915
Wedgeports
Almost 12-1
IDA's
86C + 1,4
Been using D7EA's but wondering if they are cold enough.
I need to remove fanshroud, oilcooler and tins to remove intakes so I can change plugs, so I can't just swap it out in a few minutes..
I have a new set of 7's and 8's. Which to put in?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Old Guy
Barrett Racing Pro Gas 10.75ET 123.18MPH
Re: Another sparkplug question...
May 20, 2013, 00:37:30 am »
We Run D8EAs in our 2332cc ProGas car with nearly 15 to 1 and C-12 race gas. If you run C-12 or better race gas the D7EAs ought to be cold enough. If you see any little black flecks on the white nose then the plugs are too hot.
Ron Barrett
Last Edit: May 20, 2013, 00:40:39 am by Old Guy
Old Guy
Erlend / bug66
Global Moderator
SCC Event
May 20, 2013, 00:51:15 am »
I run 98octane
The '67:
The '59:
Not yet..
Old Guy
May 20, 2013, 08:18:48 am »
Quote from: Erlend / bug66 on May 20, 2013, 00:51:15 am
I run 98octane
I think you still would be OK with the D7EA.. Just look for those black flecks I mentioned. By the way is that 98 Research Octane, Motor Octane or Research + Motor divided by 2 (like they post on the pumps here in the US).
Old Guy
Erlend / bug66
Global Moderator
SCC Event
May 20, 2013, 08:21:47 am »
Quote from: Old Guy on May 20, 2013, 08:18:48 am
I run 98octane
Ok, thanks!
Don't know the difference, but we get 98 octane on pump in Norway.
The '67:
The '59:
Not yet..
May 20, 2013, 08:33:07 am »
In Norway and Europe we use Research Octane Number. The 98 Ron should translate to a 95 ron+mon/2 value.
Erlend / bug66
Global Moderator
SCC Event
May 21, 2013, 11:57:50 am »
Think I will try a set of 8's..
it only takes 2 hours to change plugs
The '67:
The '59:
Not yet..
May 21, 2013, 12:55:25 pm »
I have run NGK 7s with 10.5/1 and 80hp of nitrous on shell optimax and also with 9/1 and 18lbs boost and saw no signs of detonation on the plugs, you really need to be able to access the plugs easier to be able to know for sure, a plug chop after a full pass gives so much information. I made some cylinder tins that the end that you access the plugs through was removable and this cuts the time needed but 75%, I am not sure if it would solve all your problems with those short manifolds or not though
Erlend / bug66
Global Moderator
SCC Event
May 21, 2013, 12:58:22 pm »
There is no chance in h**l to change plugs without taking the manifolds off
Ordered a set of both, and will try the 8's first to see how it feels
The '67:
The '59:
Not yet..
May 21, 2013, 13:59:09 pm »
I made a special wrench out a modified socket, once I get the plugs loose I can undo them with my fingers.
And I also split the sheet metal like Richie says.
Erlend / bug66
Global Moderator
SCC Event
May 21, 2013, 14:03:21 pm »
There is just no room. Not even with a turned down socket. The plugs will hit the manifold. I need to pull shroud, alternatorstand, cooler etc to remove sheetmetal then manifolds
In that direction
The '67:
The '59:
Not yet..
dragvw2180
May 21, 2013, 14:10:01 pm »
If you do not mind modifying your body, alot of people install removable windows in the quarter panel to gain access to the plugs easilly. With the windows removed you have a straigt shot at the plugs with an extension and socket. This is what I am talking about.
http://ebasic.easily.co.uk/01101C/024024/hipacshowto.html
Hope this helps, Mike McCarthy
May 21, 2013, 14:25:42 pm »
Erlend, please take a picture in order to show people what your spark plug problem is. As I remember, your short manifolds dont allow you to use any tools and in order to get your manifolds off you need to strip your engine to a long block.. basically.
Erlend / bug66
Global Moderator
SCC Event
May 21, 2013, 14:27:59 pm »
Quote from: BeetleBug on May 21, 2013, 14:25:42 pm
You are right
I will take a picture the next time I am in the garage.
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
May 22, 2013, 23:07:01 pm »
Here is some photos from today. I installed a set of 8's and will try them out.
Pretty tight..
The '67:
The '59:
Not yet..
Old Guy
May 23, 2013, 21:58:31 pm »
Wow Erland, that is tight!
Let us know how the D8EAs work out. What gap do you normally run?
Old Guy
Erlend / bug66
Global Moderator
SCC Event
May 23, 2013, 22:07:02 pm »
This set was set to .7mm.
Same for the 7's. Seemed to work fine, but I could be way out on the field!
The '67:
The '59:
Not yet..
