November 04, 2026, 07:20:27 am
| | |-+  Road Speed and Ratios
Author Topic: Road Speed and Ratios  (Read 4657 times)
Shane Noone
« on: May 23, 2013, 21:12:04 pm »
Hey guys, Just looking for a rough idea based on others experience with known ratios.
If I say I run a 205/70/15 rear tyre but I am unsure of my 4th gear ratio ( close ratio ) and unsure of my Ring and Pinion ( most likely 4.125 or 3.875 ) but my road speed at 3500 RPM's in 4th gear is 55 mph ( on the speedometer driven by 145/80/15 front tyre ) then has anyone run close to this road speed in 4th with a 205/70/15,  that knows their ratios's..Huh??
Shane.
adrian
« Reply #1 on: May 23, 2013, 22:02:39 pm »
4.125 and 1.21 gives you close to 55 mph, a 3.875 would be about 58mph. Its all pretty close though... and there are probably a ton of combos that will get you close to that mph
Shane Noone
« Reply #2 on: May 23, 2013, 23:06:02 pm »
Ok, thanks. Yeah found a gear ratio calculator programme that I can plug my " knowns" into now to get some idea on my ratios :-)
Cheers.
ALB
« Reply #3 on: May 23, 2013, 23:54:05 pm »
You're speed is fast by about 4% (a 145/80 is approx 24" tall vs a 155R at about 25") so don't forget to factor that in.
