August 12, 2026, 19:02:43 pm
| | |-+  springplate setting og height
Author Topic: springplate setting og height  (Read 4798 times)
« on: May 29, 2013, 13:26:57 pm »
guys,
i am installing the rear suspension,
but i dont remember the angle of the springplate in unstressed form,
i remember the springplate sat just above or under the blothole for the sidecovers
can you help me?
 thanks
Russell
« Reply #1 on: May 30, 2013, 21:57:12 pm »
to be honest if your using brand new same size torsion bars this will be important, if your using old slight sagging, i would go with eye but ensure car sits level and both sizes measure the same, nothing worse than seeing standard bugs down at the back because the torsion bars are worn.....
Russell, Hope this helps
Best Regards
Russell
« Reply #2 on: May 31, 2013, 04:49:51 am »
When I was re-assembling my Mexican Beetle onto itīs German chassis, my Mexican friend showed me the ROT.  Set the angle so that the bottom edge of the spring plate just skims the top edge of the lower rear bolt hole for the spring plate.  When set this way, the car will have a very slight positive camber on the rear wheels when empty.  Then with you and your mate are in, it will be a bit negative.
« Reply #3 on: May 31, 2013, 10:32:23 am »
thanks guys,
thats what i needed to know Smiley
« Reply #4 on: May 31, 2013, 11:30:16 am »
And remember if it comes in a little below, turn the inner end of the torsion bar towards the front of the car one spline at the time until you get it exactly right.
It it comes out a little above, turn the inner end towards the rear of the car.
Dustin
« Reply #5 on: May 31, 2013, 16:00:24 pm »
Check the charts here for actual angles in degrees...
http://www.swayaway.com/TechRoom_VWguides.php
Der Kleiner Panzers III
www.dkpcarclub.com
'69 Tangerine Orange Karmann Ghia- In progress
'66 Marina blue Chevy II Nova Hardtop- Project mothballed
deano
« Reply #6 on: June 02, 2013, 02:44:54 am »
One of the many reasons to switch to a SAW torsion bar is one, to get rid of the older/sagging bars, and two, you don't have  to wind them up with preload! They slip in much easier.
Anglia Obsolete Guru
'67 Heaven
