October 02, 2026, 15:38:39 pm
| |-+  Wanted
| | |-+  Scat Killer case wanted
Author Topic: Scat Killer case wanted  (Read 3542 times)
Bernard Newbury
9.50 @ 141 MPH
« on: May 31, 2013, 19:38:37 pm »
Wanted Scat killer case. 101.6mm. Wet sump Flange crank. Would prefer new.
Rocket Ron
It's old school for a reason
« Reply #1 on: May 31, 2013, 19:50:52 pm »
I'm sure you know but there's one on the samba, wet sump, flange crank and type 4 mains but its only 96mm, don't know if there enough room to bore for 101.6 or if that's special order
http://www.thesamba.com/vw/classifieds/detail.php?id=1407981
13.12 @ 101.84
Grooving out on life
Bernard Newbury
9.50 @ 141 MPH
« Reply #2 on: May 31, 2013, 20:38:43 pm »
Thanks. I have been speaking to him but there is too much work to move the studs out to the correct position for 4". You would have to machine very deep to get enough room to weld the old stud holes.  If only  Wink
