October 12, 2026, 10:12:36 am
Project 56..
5
7
Topic: Project 56.. (Read 195781 times)
kev d
Re: Project 56..
Reply #60 on:
March 21, 2014, 19:59:44 pm »
How many have you seen with non standard front seats that almost touch the back seat though...
kev d
Re: Project 56..
Reply #61 on:
April 06, 2014, 22:53:45 pm »
Its all glamour this car building...
kev d
Re: Project 56..
Reply #62 on:
July 31, 2014, 18:14:13 pm »
Dragged the 56 back home yesterday
Got a bit more bodywork to do after blasting it as it showed up a couple of areas that were thinner than expected, nothing serious but not going to cut corners at this stage!
I'm replacing both rear bumper mounts with hookeys panels & also both heater channel bottom plates so I can blast & treat any rust inside the channels.
Going to make a hole in the roof too..
kev d
Re: Project 56..
Reply #63 on:
August 07, 2014, 22:52:15 pm »
Decided do dive into the ragtop graft... Seemed more interesting than the other jobs I could've been doing
Got the hole cut & new section sitting in place, next stage is the finish cut on the roof & start welding
BossHogg76
Re: Project 56..
Reply #64 on:
August 08, 2014, 13:10:33 pm »
Big balling it there Kev, I'd have been bricking it cutting a hole that big
kev d
Re: Project 56..
Reply #65 on:
August 08, 2014, 19:48:02 pm »
It's only metal mate, cut off too much & it'll weld back on!
Funnily enough my woodworking is pretty crap...
kev d
Re: Project 56..
Reply #66 on:
August 17, 2014, 11:36:54 am »
Job done!
Took my time welding it in & ended up with very little distortion, found that tacking in the front corner braces 1st worked better but they did need modifying as the donor roof was a 60's car.
Going to lead load the join just because I want to learn how to do it
Next step are the rear bumper mounts & removable valance.
fahrvergnugen
Re: Project 56..
Reply #67 on:
August 17, 2014, 12:43:35 pm »
Cool. nice job Kev.
http://fast-air.skynetblogs.be/
kev d
Re: Project 56..
Reply #68 on:
August 17, 2014, 16:55:15 pm »
Quote from: fahrvergnugen on August 17, 2014, 12:43:35 pm
Cool. nice job Kev.
Cheers!
kev d
Re: Project 56..
Reply #69 on:
December 06, 2014, 19:32:37 pm »
First time back onto the 56 in months so starting out with easy stuff!
This is going to get lots of miles on it with the kids so one job was always going to be seat belts.
For the front I've used the upper B post mounts salvaged from a 74 I broke.
The lower B posts will need a small 'box' made with the correct captive nut & tied into the heating channel.
At the back I'm using modern late hatchback inertia reel belts hidden under a parcel shelf.
Pics to follow
Body wise I've got the rear bumper mounts & valance tacked into place but really need a good w deck lid before final welding. It's had a small shunt at the back that's bent the deck lid & I don't want to weld anything till I've got all the panels that'll be staying with it!
Kev
kev d
Re: Project 56..
Reply #70 on:
December 30, 2014, 22:02:54 pm »
Had a bit of garage time lately so managed to get a bit more metalwork done
The rear bumper mounts are finished, this is the first time I've used Hookeys panels but these fitted perfectly, the heater channel closing plates are just as good too
I've removed the bottom plates so I could treat & rust proof the heater channels, very happy with what I found too, just some slight 'browning' & no rot!
Well worth doing even if it was a bit of a hassle. I'll finish the lower B post seat belt mountings before fitting the new closing panels so I can get everything properly painted first.
Also got the wheel well lower panel removed & repaired some minor damage to the front valance.
Its coming together now..
BossHogg76
Re: Project 56..
Reply #71 on:
December 31, 2014, 07:02:27 am »
Looking good Kev, how colds the garage at the moment?
kev d
Re: Project 56..
Reply #72 on:
December 31, 2014, 12:23:53 pm »
Not too bad, the big heater helps though!
kev d
Re: Project 56..
Reply #73 on:
February 05, 2015, 09:53:53 am »
Replaced the wheel well while it was still on its side, much easier!
Next job is to make the front lower seat belt mounts then paint the inside of the channels before fitting the new closing panels.
Ideally I'd like a N.O.S rear apron to finish of the rear but will probably end up using one of the quality repro parts that's available.
kev d
Re: Project 56..
Reply #74 on:
May 07, 2015, 20:11:14 pm »
Update time
I've made the lower B post seat belt mounts then treated & epoxy primed the inside of the heating channels, boring job but glad I did it anyway!
After that I cleaned the underside back to bare steel & gave everything 2 coats of epoxy primer, I'll leave it to cure then seam seal all the joins before stonechipping everything. It'll all be painted body colour, not an original or 'show' finish but I'm building it to be used & last.
While it was still on its side I did the inside of the roof too.
Next stage is get stuck into the bodywork & get it ready for primer..
56BLITZ
Re: Project 56..
Reply #75 on:
May 07, 2015, 23:13:21 pm »
Quote from: kev d on May 07, 2015, 20:11:14 pm
I've made the lower B post seat belt mounts . . .
Are they the new bits seen inside the heater channels?
Lookin' good Kev . . . keep up the nice work!
Rocket Ron
It's old school for a reason
Re: Project 56..
Reply #76 on:
May 08, 2015, 00:03:32 am »
Some sensible mods there Kev.
13.12 @ 101.84
Grooving out on life
Re: Project 56..
Reply #77 on:
May 08, 2015, 02:28:55 am »
Looks great man!
PS: I bet the wife's a bit upset at sleeping on the couch until the mattress isn't needed by the Beetle any more............
kev d
Re: Project 56..
Reply #78 on:
May 08, 2015, 06:14:58 am »
Quote from: modnrod on May 08, 2015, 02:28:55 am
Looks great man!
she's a trooper, knows it's all in a good cause!
Quote from: 56BLITZ on May 07, 2015, 23:13:21 pm
Yep, basically a piece of 2.5mm wall box section with a mounting face & captive nut. It's welded to the inside of the channel & plug welded through the new bottom plates.
Quote from: Ron Elliot on May 08, 2015, 00:03:32 am
Cheers Ron
, how's tricks?
GASBNR
Re: Project 56..
Reply #79 on:
May 08, 2015, 07:29:55 am »
Good stuff there Kev.
SUPPORTING CAL-LOOK DOWN UNDER
kev d
Re: Project 56..
Reply #80 on:
May 08, 2015, 08:22:04 am »
Cheers!
Wray
Re: Project 56..
Reply #81 on:
May 08, 2015, 11:28:21 am »
What about the drag car is it going to drag day?
kev d
Re: Project 56..
Reply #82 on:
May 08, 2015, 11:40:01 am »
'Fraid not
I'll get it out eventually!
BossHogg76
Re: Project 56..
Reply #83 on:
May 08, 2015, 16:30:51 pm »
Looks good mate, are you going to the Drag day at all?
kev d
Re: Project 56..
Reply #84 on:
November 22, 2015, 16:36:37 pm »
Well no new pics worth posting but there's been some progress!
Most of the body work is done & its hopefully going to be in paint before long.. Just means I'm running out of time to settle on a colour
Larry S
Re: Project 56..
Reply #85 on:
January 03, 2016, 13:09:47 pm »
Kev,
I need to replace my rear bumper mounts as well, I went to the web site of the company you mentioned but it only lists those for a 60-67 model, is this what you used? You are doing a great job on the car!
Thanks for your help!
Larry
kev d
Re: Project 56..
Reply #86 on:
January 03, 2016, 15:38:54 pm »
Hi Larry,
Without digging out the invoice I can't be sure tbh!
I e mailed him before ordering & the panels I got were 100% the same as the originals & were a lovely fit
Can't recommend him highly enough!
Kev
Larry S
Re: Project 56..
Reply #87 on:
January 03, 2016, 17:56:41 pm »
Thank you Kev, I have reached out to them. Your car is looking great, you are doing an amazing job. I should have a rolling chassis soon and will be tackling the body soon as well.
Larry
kev d
Re: Project 56..
Reply #88 on:
January 03, 2016, 19:05:04 pm »
No probs!
Keeping an up to date build thread I hope?
Kev
Larry S
Re: Project 56..
Reply #89 on:
January 03, 2016, 23:37:00 pm »
Kev, Yes I do have a thread under In Da Works named MY NEW 56 PROJECT, you have even posted to it. I have not updated for a long time but I am getting ready to. I have got a lot done recently, chassis should be rolling soon. I have done some body work but hope to really dig in soon. thanks for the info!
Larry
5
7
