May 20, 2026, 22:50:39 pm
mvptkfjb
Interesting turbo set up
Topic: Interesting turbo set up (Read 8109 times)
June 09, 2013, 09:32:03 am »
a thread just started on the samba, anybody with any info on this?
Re: Interesting turbo set up
June 09, 2013, 10:10:09 am »
looks like a pro charger to me, crank driven super charger, takes a lot to drive it though
dannyboy
June 09, 2013, 10:39:44 am »
isnt this why superchagers arnt common for vw motors? it takes to much power to run them up? or am i talking crap again
8.77@156.8mph
O/FF 60
June 09, 2013, 10:51:56 am »
looks the bollox though.
Perhaps they should now fit supercharger and turbo, best of both worlds.
Griebel
June 09, 2013, 11:17:44 am »
Hails from Revmasters "Scorpion II"
http://ultimateaircooled.com/simplemachinesforum/index.php?topic=9008.0
Griebel
Instagram: c.griebel
"BEYOND 4 INCHES"
MIB,DENMARK
June 09, 2013, 12:33:11 pm »
Quote from: dannyboy on June 09, 2013, 10:39:44 am
It does, but for me packaging is proberly the biggest problem, that set up would only really work in a front engine application
June 09, 2013, 12:34:13 pm »
Quote from: Griebel on June 09, 2013, 11:17:44 am
Griebel
I kept looking at the gold case and thinking I am sure I recognise it, but couldn't think where from, now I know
fastbus
June 09, 2013, 19:20:13 pm »
Interesting!
Surely a crank driven turbo induction system wouldn't use as much energy as a supercharger?
The working of a supercharger are far heavier in weight than a turbo fan.
Looking at the picture of there system it only uses an intake fan so that should reduce the energy required and make boost instantly.
Not sure about how fast it will spin compared to a normal turbo. Maybe its a geared set up?
13.66@102mph in my old T3 crew cab builders truck!
13.01@109mph in my bug so far!
DWL_Puavo
June 09, 2013, 21:45:49 pm »
Procharger uses normal gearing, rotrex uses planetary gears to multiply rpm's. Thus the boost rises with rpm's which can be problematic as normal turbo's usually reach their max boost somewhere in the middle of the rpm's. Surely stupid idea: how about to use reversed variator from scooter to drive procharger?
Greg G
June 10, 2013, 03:21:55 am »
their dragster has made some good passes.
http://bowtie0069.fotki.com/2013-irwindale-pix/bug-in-irwindale-2013/img-7099.html
https://www.facebook.com/media/set/?set=a.432761280071636.117234.316970098317422&type=3
June 10, 2013, 03:27:14 am »
You guys have it pegged. We talked to the the guy yesterday at AJ Sims. It's a Procharger that's run off the nose of the crank through a gearbox.
Last Edit: June 10, 2013, 03:44:03 am by DKK Rick
June 10, 2013, 03:29:57 am »
Ok I looked at the picture again... that's me to right in the black shirt and red Vans. To the left are fellow DKK members, Tod Fuller, Nanci Mayeda and Robert Baldwin.
kingsburgphil
June 11, 2013, 00:27:53 am »
For what it's worth. A Miller 91 from the 20's
spanners
June 11, 2013, 20:30:42 pm »
As above, there's nothing new exciting me, the earliest ever engines had turbos designed in from day one, they failed material wise, compounded turbos, muted next year in F1, were done in the 40's. Turbo+ superchargers are old hat, the VW Polo is on that just now, about all we have is better control from electronics, and better and newer materials.
Best regards, spanners.
