October 12, 2026, 21:36:07 pm
Typ3 rear drum up-grade
Topic: Typ3 rear drum up-grade (Read 7248 times)
zaza1
June 09, 2013, 12:38:48 pm »
hi, i don't understand a type different setting
http://airkewld.com/products-page/drum-kits/5x4-75-rear-drum-kit-longirs-spline/
and that part
http://airkewld.com/products-page/drum-kits/5x4-50-rear-drum-kit-longirs-spline/
who's a different size 4.50 or 4.75.
i have a original trasmission.You bought this change for the attack 4x130 or modify the original rear drum?
my work in progress
http://recidivo.tumblr.com
Re: Typ3 rear drum up-grade
June 09, 2013, 14:15:15 pm »
Quote from: zaza1 on June 09, 2013, 12:38:48 pm
and that part
my work in progress
The 1st kit is for Chevrolet stud pattern wheels [5x 4.75] and the 2nd is for USA ford stud pattern wheels [5x4.50] You can buy late type 3 drums in 4x130 and just have them machined to fit the early short axle
zaza1
June 09, 2013, 14:25:51 pm »
Tanks Richie
June 09, 2013, 20:03:35 pm »
Quote from: richie on June 09, 2013, 14:15:15 pm
and that part
my work in progress
yep. maybe good to point out that the later drums on a type3 are a two piece design. you have the actuall brake/drum and a rotor with the boltpatern. you need both. and the hub/rotor is shortened to fit short axles.
zaza1
June 09, 2013, 20:06:11 pm »
change all the braking system so
... but these already offering complete kits and do not go well?
UltraOrange67-2443
June 09, 2013, 21:33:47 pm »
I found wide 5 T3 rear brakes on a Karmann ghia I'm working on, they had long axles.
I fitted short race axles & tubes but had the new drum snout machined down to suit.
You can fit a late T3 rotor and drum and do the same if the axles you have are short.
1967 1200 2920cc EFI
