September 23, 2026, 23:39:36 pm
Mounting External Oil Cooler - frame ideas or best position
Topic: Mounting External Oil Cooler - frame ideas or best position (Read 6642 times)
stait9
June 11, 2013, 21:39:46 pm »
Hi everyone
I've got to mount a new cooler and was wondering if anyone has some advice or pictures on where best mount it, in particular any ideas of good brackets. The previous one was simply mounted to the underside with some rubber mounts. It resulted in slightly restricted air flow and I've seen a couple of pics and cars but it's quite hard to get right under cars at shows. Also just discovered a friend can build any Aluminium frame I just need so help designing it.
Stuart
Re: Mounting External Oil Cooler - frame ideas or best position
June 11, 2013, 22:00:13 pm »
stait9
June 11, 2013, 22:18:52 pm »
Thanks Lids, quick question - is this set up running a cooling fan?
Jesse/DVK
'64 2176cc
June 11, 2013, 22:32:16 pm »
Check this really nice set up of Felix in his topic.
http://cal-look.no/lounge/index.php/topic,12030.60.html
stait9
June 11, 2013, 22:36:02 pm »
Thanks, that's great
Tobi/DFL
June 12, 2013, 09:01:19 am »
Hi,
this is what I made for my car.
[ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
Bye,
Tobi
June 12, 2013, 19:02:03 pm »
Quote from: stait9 on June 11, 2013, 22:18:52 pm
i don't think so as it is mounted to the torsion bars, it could be made to work though. This is a pre made kit
Sepi
June 14, 2013, 20:55:56 pm »
I did this way to my -59. Adjustable with thermostat fan.
stait9
June 14, 2013, 22:45:29 pm »
Thanks looks great Sepi. Thanks for posting
Tourist
June 14, 2013, 23:07:46 pm »
Quote from: Sepi on June 14, 2013, 20:55:56 pm
Sepi,
What size of u-clamps and oil cooler/fan set up did you use?, that looks really neat.
Martin.
Sepi
June 15, 2013, 22:10:34 pm »
I used a 75 mm clamps for exhaust - which is 3". Then some welding for brackets and now this is adjustable. Just simple innovations here and there-
The fan is a 8" from Australia - don't remember the manufacturer
Last Edit: June 15, 2013, 22:14:12 pm by Sepi
