September 24, 2026, 00:30:36 am
| | |-+  Mounting External Oil Cooler - frame ideas or best position
Author Topic: Mounting External Oil Cooler - frame ideas or best position  (Read 6648 times)
stait9
« on: June 11, 2013, 21:39:46 pm »
Hi everyone
I've got to mount a new cooler and was wondering if anyone has some advice or pictures on where best mount it, in particular any ideas of good brackets.  The previous one was simply mounted to the underside with some rubber mounts.  It resulted in slightly restricted air flow and I've seen a couple of pics and cars but it's quite hard to get right under cars at shows.  Also just discovered a friend can build any Aluminium frame I just need so help designing it.
Stuart
« Reply #1 on: June 11, 2013, 22:00:13 pm »
stait9
« Reply #2 on: June 11, 2013, 22:18:52 pm »
Thanks Lids, quick question - is this set up running a cooling fan?
« Reply #3 on: June 11, 2013, 22:32:16 pm »
Check this really nice set up of Felix in his topic.
http://cal-look.no/lounge/index.php/topic,12030.60.html
stait9
« Reply #4 on: June 11, 2013, 22:36:02 pm »
Thanks, that's great
Tobi/DFL
« Reply #5 on: June 12, 2013, 09:01:19 am »
Hi,
this is what I made for my car.
Bye,
Tobi
« Reply #6 on: June 12, 2013, 19:02:03 pm »
i don't think so as it is mounted to the torsion bars, it could be made to work though.  This is a pre made kit
Sepi
« Reply #7 on: June 14, 2013, 20:55:56 pm »
I did this way to my -59. Adjustable with thermostat fan.
stait9
« Reply #8 on: June 14, 2013, 22:45:29 pm »
Thanks looks great Sepi.  Thanks for posting
Tourist
« Reply #9 on: June 14, 2013, 23:07:46 pm »
Sepi,
What size of u-clamps and oil cooler/fan set up did you use?, that looks really neat.  Cool
 Smiley
Martin.
Sepi
« Reply #10 on: June 15, 2013, 22:10:34 pm »
I used a 75 mm clamps for exhaust - which is 3". Then some welding for brackets and now this is adjustable. Just simple innovations here and there-
The fan is a 8" from Australia - don't remember the manufacturer
« Last Edit: June 15, 2013, 22:14:12 pm by Sepi » Logged
