September 23, 2026, 22:15:00 pm
| |-+  For sale!
| | |-+  Cog box street beetle gearbox only 50 miles...pending stuart
Author Topic: Cog box street beetle gearbox only 50 miles...pending stuart  (Read 3490 times)
Hurstvw
« on: June 18, 2013, 21:23:05 pm »
Built in 2011 by pete englezos, cogbox. and only done 50 (run in) miles. Type 1 swing axle gearbox.
Super beetle 1st gear 3.78, 2nd gear 2.06
3rd gear 1.31 weld and hone hub
4th gear 1.00 weld and hone hub
Heavy duty super diff / 4 spider gears and 2 side gears
Heavy duty short axles
Heavy duty short axle tubes with solid boots and bearings
Steel forks
Steel caged bearings
£1400 obo
« Last Edit: June 21, 2013, 11:34:21 am by Hurstvw » Logged
72 Cartune Beetle
72 GTV Beetle
77 Westfalia Camper
stait9
« Reply #1 on: June 18, 2013, 22:29:46 pm »
Hi
What R&P does it have?
What size engine was it built for?
Stuart
Hurstvw
« Reply #2 on: June 18, 2013, 22:35:21 pm »
Built for 165 bhp 2007cc motor. Split screen van nose one with hockey stick
72 Cartune Beetle
72 GTV Beetle
77 Westfalia Camper
stait9
« Reply #3 on: June 18, 2013, 23:02:41 pm »
Cheers.
Don't suppose you know the Ring & Pinion ratio, is it 3.88 or higher?  Or have I missed it?  If so, sorry.
Hurstvw
« Reply #4 on: June 18, 2013, 23:41:38 pm »
It's 3.88
72 Cartune Beetle
72 GTV Beetle
77 Westfalia Camper
