September 22, 2026, 11:59:29 am
| | |-+  Rod journal marks.
Author Topic: Rod journal marks.  (Read 4310 times)
Taylor
« on: July 02, 2013, 11:06:54 am »
Late night question for everyone.   I took the top end of my motor apart because I found some aluminum in the filter.  Everything looks better than I could hope for, even the oil pump.  The rod bearings don't look bad but I'll replace them anyway.  To my question:  the back side of the rod journals have some marks on them.  They don't look that bad and I can't feel the marks.  My question is what would cause the marks to be only on the backside?   If something went through I would think the marks would round the circumference.  The marks are lines consistent with debris going through.  Maybe it was the 24 dyno pulls.
« Reply #1 on: July 02, 2013, 11:10:33 am »
Taylor
can you put a pic up so we can see exactly what you describe?
Taylor
« Reply #2 on: July 02, 2013, 11:15:21 am »
I could maybe tomorrow,  but the crank is still in the case and I can't get a good picture.
« Reply #3 on: July 02, 2013, 11:35:01 am »
Ok, do you mean the underside of the crank on the rod journal? how do the cap side rod bearings look? worse than the rod side?
Taylor
« Reply #4 on: July 02, 2013, 11:38:43 am »
Maybe a little worse.   So at top dead center,  the part of the journal that is marked is the cap side, like you say.
