September 24, 2026, 08:29:08 am
| | |-+  Mendeola transmissions
Author Topic: Mendeola transmissions  (Read 8765 times)
Andy Sykes
« on: July 04, 2013, 20:44:51 pm »
Hi guys I have more transmission issues with my vertigate 930 box
1 the ratios are shite
2 the diamentions from the starter to the flywheel are way out
So I'm seriously thinking of scrapping it as at the moment it's no use to anybody it don't fit and it won't work
So what Mendeola box I've looked at web site and I'm confused lol you can't get vertigate but can you also have pro rings ?
Cheers andy
« Reply #1 on: July 04, 2013, 21:08:55 pm »
The 2nd one down is for you
http://ranchotransaxles.com/pbs-transaxles.html
Andy Sykes
« Reply #2 on: July 04, 2013, 21:33:12 pm »
Cheers that looks like a proper job do you know if hey are much longer than a standard box ?
Cheers andy
« Reply #3 on: July 05, 2013, 08:07:19 am »
Cheers andy
at least 2 inches longer than a type 1 box, with IRS you can move the box into the car more,better than with swingaxle were you are screwed and it moves the engine back.
To answer your original question, a Mendeola MD4 drag[still over 2inches longer than a type 1 box] can be ordered with the provision for the Vertigate shifter, mine is that way, and either syncros or Pro ring/slick shift, the 2 things are not connected, the vertigate shifter is how the gears are selected, the syncros or pro rings are how the gears are engaged.
 But none of that will not overcome the fact that your cage etc is in the way of the path the shift rods would take.
My flywheel to starter distance is still not ideal and really the case needs machining where the starter bolts on to bring the starter in more, but I believe there is more of an issue with the flywheel you chose, supposedly its way off where it should  !!!!!!
Andy Sykes
« Reply #4 on: July 05, 2013, 18:19:52 pm »
Cheers thanks I will make it fit lol if they answerd their phone I could order one lol
« Reply #5 on: July 05, 2013, 18:26:17 pm »
PM
Andy Sykes
« Reply #6 on: July 07, 2013, 10:51:15 am »
I've been pointed Ito this thread looks interesting
http://ultimateaircooled.com/simplemachinesforum/index.php/topic,13692.0.html
Cheers andy
Basti
« Reply #7 on: July 09, 2013, 12:23:50 pm »
Buy a mendy case and a r/p, send me the ratios you
Want and i check it. If possible i build you a full sequential gearbox Out of it...
Cheers,
Basti
- black 62 cal look beetle
- Pro Mod Race car
Andy Sykes
« Reply #8 on: July 09, 2013, 21:55:59 pm »
Hi sounds interesting send me some details
Cheers Andy
bedjo78
« Reply #9 on: July 10, 2013, 00:14:01 am »
I got mendy 2D box from rancho, and later found out that Jussy making dog ring for mendy. . .  Undecided
mendy case + dog ring from Jussy of finland .....
Jussifin
« Reply #10 on: September 13, 2013, 21:06:39 pm »
We have now Mendeolas with Finnish dogring gears in use. One with vertigateshifter in turbouse (Jyrkis pauter-oval) + normal shifter in my -51 N/A racer. Of cource the Mendeola is more weight into car, but then you can consentrate on doing the car more light elsewhere and just drive and not repair gbox after every weekend...
Now we have plenty of gears in stock and i will be with those in JPM-dynoday.
Ask for more: info@kuplapaja.com
Jussi Wink
