November 04, 2026, 10:10:07 am
Rear apron deck lid stand off
Topic: Rear apron deck lid stand off (Read 7584 times)
Garrick Clark
July 09, 2013, 20:43:31 pm »
Hi guys.
Is there anyone selling the deck lid stand offs that fit on the rear valance.
It for a 67 bug.
Or can anyone make me 1.Preferably in stainless.
Thanks G.
Air cooled Engine builder
56BLITZ
Re: Rear apron deck lid stand off
July 09, 2013, 22:45:12 pm »
Like this . . .
http://www.vintagespeed.com.tw/Accessory/Deck-Lid-Bottom-stand-off.html
They miss your year, but you might be able to use the early one and drill some holes to screw it on with the latch screws.
Last Edit: July 09, 2013, 22:49:06 pm by 56BLITZ
Jesucristo es mi Seņor y Salvador!
July 09, 2013, 23:39:50 pm »
if you can find two 6mm 411 oil cooler studs and find/fab some kind of pretty tubular spacer, you can make a nice standoff using the orig VW latch. To keep the tubes from marring apron, use two VW 111821545 running board-to-fender grommets.
July 10, 2013, 00:09:04 am »
Or you can just use some long bolts and spacers with your original latch. A 66 latch is spaced out a little more and works good too.
July 10, 2013, 01:00:33 am »
Quote from: Bryan67 on July 10, 2013, 00:09:04 am
A 65-66 latch is spaced out a little more and works good too.
That's what I used, but I extended the bottom so the rubber bumper would have something to bump against.
Garrick Clark
July 10, 2013, 21:09:50 pm »
Hey guys thanks for the ideas.
I do have some type 4 studs.
I'll give the spacer trick a try.
Cool.
Hotrodvw
July 15, 2013, 08:21:56 am »
I'm trying to find a better picture, but this is the Vintage Speed stand off for a '67. It's stands it off approx. 3.5-4".
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
Garrick Clark
July 15, 2013, 19:52:24 pm »
That's how I need mine to be.
I've got some of the other type that fit on the hinges but when it rains
the motor gets wet.
The other reason i'm after 1 of these is cause I've got a type 4 motor in it with a stainless header and muffler.
the header and muffler being stainless gets proper hot,so the back valance stand off will allow the heat to escape and hopefully wont heat soak the engine.
56blitz got it right.
They don't do for 1 for a 67.
I recon there's a bit of a market for ones that fit a 67.
So who can make me 1 out of ally or stainless.
Thanks G
Last Edit: July 15, 2013, 20:04:47 pm by GARRICK.CLARK
sambaboy
July 15, 2013, 22:59:21 pm »
Hope this link works!
http://limebug.net/product/view/1054/billet-stand-off-for-early-w-and-half-w-declklids
says its for an early lid but dont know if it could be made to fit a later bug.
TheNick80
July 16, 2013, 07:47:56 am »
Here is the one I made for my 67. Aluminum bar stock, and some aluminum hex turn buckles I found at a hardware store. Drilled and re-tapped for 6mm hardware. It's 2.625" (67mm) tall. [ Attachment: You are not allowed to view attachments ]
It Maybe a bit crude, but it cost $15.00 to make. And you can still lock your deck lid
Last Edit: July 16, 2013, 07:51:19 am by NICK_67
"There is a Fine line between stupid and Clever"
