September 22, 2026, 17:21:07 pm
| |-+  Wanted
| | |-+  Saco clutch master cylinder
Author Topic: Saco clutch master cylinder  (Read 6710 times)
UltraOrange67-2443
« on: July 11, 2013, 09:33:23 am »
I'm after a Saco clutch master cylinder.
I have damaged it and have tried to contact Saco many time with no success  Cry
Has anyone got a spare they are not using?
Cheers, Nick.
1967 1200 2920cc EFI
« Reply #1 on: July 12, 2013, 06:05:11 am »
Sorry to learn about your problem. May I ask what happened? Not possible to hone it slightly?
-BB-
UltraOrange67-2443
« Reply #2 on: July 12, 2013, 07:43:44 am »
-BB-
Hi BB,
One of the threaded holes has been damaged and leaks.
I don't want to risk using it.
I just wish Saco would reply to my emails, I don't want to buy another full kit!
Cheers, Nick.
« Reply #3 on: July 12, 2013, 08:09:54 am »
-BB-
Hi BB,
Cheers, Nick.
Just drill and tap it. If it is the threads then there should be plenty of products out there capable of taking care of leaking threads.
-BB-
UltraOrange67-2443
« Reply #4 on: July 25, 2013, 22:17:25 pm »
Still looking!
bang
« Reply #5 on: July 29, 2013, 21:02:13 pm »
is that the one sitting in the tunnel? or the one on the gearbox?
have e new one of them sitting in the tunnel
UltraOrange67-2443
« Reply #6 on: July 29, 2013, 22:22:50 pm »
Its the master cylinder I'm after (in tunnel)
Cheers, Nick
UltraOrange67-2443
« Reply #7 on: August 12, 2013, 23:17:41 pm »
Any joy dude?
Stripped66
« Reply #8 on: August 14, 2013, 02:16:49 am »
I recently replaced my SACO with a Wilwood, and fabbed up a new mount inside the tunnel. If you can cut, drill and weld, you can do it, too. You're welcome to my old M/C, but it needs a rebuild kit ( http://www.sacoperformance.com/proddetail.php?prod=32-1002MCKIT ). I just can't see putting any effort into keeping a SACO M/C. It's going to fail on you one way or another.
UltraOrange67-2443
« Reply #9 on: August 14, 2013, 19:58:57 pm »
Got one now.
Did you have problems with your Saco one?
Stripped66
« Reply #10 on: August 16, 2013, 23:23:59 pm »
Absolutely. It's an aluminum M/C that is not hard-anodized. You'll know it when your hydraulic fluid starts to appear silvery/glittery.
