August 13, 2026, 02:21:42 am
| | |-+  Fuel cell advice
Author Topic: Fuel cell advice  (Read 5430 times)
Rocket Ron
It's old school for a reason
« on: July 11, 2013, 23:20:43 pm »
Been collecting parts for my next project a purpose built drag car and been looking at buying a fuel cell when I'm next in the US
Looking at his from summit racing http://www.summitracing.com/parts/jzp-250-303-01/overview/
Any comments on suitability would be great
Regards Ron
13.12 @ 101.84
Grooving out on life
Mike Lawless
« Reply #1 on: July 12, 2013, 15:41:38 pm »
Personally, I'm not a big fan of plastic fuel cells, although they have some advantages. For example, it's easier to change the fittings if another size is needed.
It's hard to keep them sealed up. I've had to resort to making sealing rings from a different material, and using some sort of sealant as well.
There are nice low cost aluminum cells such as this one, also available from Summit.
http://www.summitracing.com/parts/sum-291203/overview/
JAZ and RCI make nice cells too.
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
Rocket Ron
« Reply #2 on: July 12, 2013, 17:40:13 pm »
Thanks Mike
It's always nice to get some real world feedback before buying these sort of things
Regards Ron
13.12 @ 101.84
« Reply #3 on: July 12, 2013, 18:15:25 pm »
If you are using it on a relatively stock front end with a beam,then that shape is a real pain to fit, a cell that is more like the stock tank shape is easier to get in the space, and unless you want to drive it some distance you can use a smaller tank then that unless you use alcohol based fuels[E85,methanol etc]
dannyboy
« Reply #4 on: July 12, 2013, 18:27:21 pm »
yep i have this tank it was a  bugger to get to fit i had to lay it back slightly so it wouldnt foul bonnet or steering rods  but i did get it in mr webb sells some ally ones that would be a bit easier to fit  Smiley
8.77@156.8mph
O/FF 60
Mike Lawless
« Reply #5 on: July 12, 2013, 19:08:15 pm »
Richie's right
This is the I use (except mine is bare aluminum). The front has an angled face, fittings are at the rear. Works out really well for a VW.
http://www.summitracing.com/parts/sum-291204c/overview/
I think if I were going to use the vertical one, I'd position it sideways, and use the rearmost fitting for picking up the fuel
Rocket Ron
« Reply #6 on: July 13, 2013, 08:43:47 am »
Looking at the picture I took at pats I think the flatter type tank suggested may be a better bet
Thanks all for your input
13.12 @ 101.84
