August 12, 2026, 16:20:00 pm
| | |-+  ida 48 filter
Author Topic: ida 48 filter  (Read 21517 times)
banditina
« on: July 20, 2007, 16:56:33 pm »
hi,
can you give me any news on these filters for my IDA?
they are useful to put? which is it the company that constructs them?  K&N?  alternatives?
tnx........
empicolector
EMPI RULES
« Reply #1 on: July 20, 2007, 17:13:35 pm »
I already have seen them on ebay may you have to look for it again
I know that its stupid but did you have try the email adress on the card Wink
« Reply #2 on: July 20, 2007, 17:31:52 pm »
Serrano's carries these things too, but they are very restrictive. Try aircooled.net , they have some nice clamp-on foam filters for IDA's. Or you can check out ACE (Art Thraen) this guy makes a beautifull stack/filter combination. Hope this helpes.
Randy Jewell
« Reply #3 on: July 20, 2007, 18:07:11 pm »
hi,
tnx........
I tried some of these a couple of year back but they wouldn't let the engine rev .
Griffinsky
« Reply #4 on: July 21, 2007, 06:37:35 am »
Jim,
  You drive everywhere with open stacks? Brave man for sure. The silica in one half of a teaspoon of Northern California dust will
make your top rings run away from home. Would be nice to see a well constructed air box with an adequate filter to let the engine
go to redline without choking.
TG
« Reply #5 on: July 21, 2007, 18:30:49 pm »
And what about Ram Flo filters?
I have a set of them and planning to use it on 44idf.
« Reply #6 on: July 22, 2007, 17:59:27 pm »
I have a set of those for 48s that were given to me... I don't think I'd ever use them though.
Matt Tobias
« Reply #7 on: July 23, 2007, 06:56:01 am »
I had a set of those on my 2276 and I actually sucked the foam out of the 3/4 side into the intake.  What a mess!  I thought my engine blew when it happened!  Needless to say, I'm not running them now.  They are cool to look at though.
« Reply #8 on: July 23, 2007, 07:45:08 am »
Wow. I thought that these filters were better quality than the others... Shocked Shocked
There is a latticework inside however.
Matt Tobias
« Reply #9 on: July 24, 2007, 00:53:52 am »
Yeah, the metal screen that holds the foam in place just didn't hold it in place.  I was freaked out when it happened!
« Reply #10 on: July 28, 2007, 12:38:19 pm »
Hi Jim, thanks for the Unifilter info !
« Reply #11 on: January 13, 2008, 01:56:52 am »
Did anyone refer to these already?
How about them?
Rune
SCC Crew
Screwdrivers #7
« Reply #12 on: January 13, 2008, 03:55:56 am »
I tried those on  my last motor, for like an hour... They won't let the motor breathe, AT ALL.... In a type 1 there is just no room for good (large) enough filters.... IMO
Matt H
« Reply #13 on: January 13, 2008, 04:21:39 am »
I ran the uni filters in my car a little bit. They work OK, but do choke the motor down a little bit. John Plow ran them from Conneticut to my house in Detroit with no problems.
ESH
« Reply #14 on: January 13, 2008, 11:00:48 am »
How about them?
If you look at the steel mesh on those and then cost in the filter material you have to think that they choke down the stack 25% +. I used tall filter 'socks' for a while and they still tended to suffocate things. I saw some of the tea strainer type on ebay that were raised so the surface area is bigger but I'm not especially convinced about them either.
http://cgi.ebay.com/ebaymotors/Weber-Carb-40-44-45-48-DCOE-IDA-IDF-Stack-Filters_W0QQitemZ150169956814QQihZ005QQcategoryZ33550QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
« Reply #15 on: January 13, 2008, 11:11:38 am »
so, nobody is using any type of filters here?
ESH
« Reply #16 on: January 13, 2008, 11:28:37 am »
I did initially with DRLAs but am not currently with IDAs. I'm not overly comfortable with running open but since we have a damp climate and we don't generally have too much airborne dust to worry about so it's not as big a issue as it could be. That said I do check for signs of rodents after evey trip.
« Reply #17 on: January 13, 2008, 16:23:15 pm »
I'm thinking of having 4 nylon rings machined which are clamped on the velocity stacks with 4 motorcycle K&N's.
« Reply #18 on: January 13, 2008, 16:38:16 pm »
like this?
Bewitched666
Bewitched
« Reply #19 on: January 14, 2008, 12:41:23 pm »
Think those will filter better Died then the ones you osted before,think of doing the same when i use my IDA'S Grin
Fast vw beetle's rule
Dokke/DFL
« Reply #20 on: January 14, 2008, 12:44:57 pm »
But it doesn't look that good ... isn't it ?
Bewitched666
Bewitched
« Reply #21 on: January 14, 2008, 12:46:31 pm »
Nah is less sexy of course but running them on the road requires some sort of filtering,on the strip i will run without Grin
-jens!-
« Reply #22 on: January 14, 2008, 15:45:01 pm »
I'm using pipercross socks on my stacks, no ty-wra(r)ps needed, cheers a pee-shooter
« Reply #23 on: January 14, 2008, 16:07:17 pm »
hi jens,
did you get those somewhere in your neighbourhood?  Wink
« Reply #24 on: January 15, 2008, 01:55:06 am »
I remember Mark Herbert saying something to the effect of, "Air filters are for people who want to make their IDA's look stupid."
I agree  Grin
« Reply #25 on: January 15, 2008, 03:22:00 am »
This fits:
cal-look.net
« Reply #26 on: July 21, 2008, 13:59:53 pm »
http://www.thesamba.com/vw/classifieds/detail.php?id=602290
anyone running these?
« Reply #27 on: July 21, 2008, 17:13:10 pm »
Yes. I can´t tell any difference if I run them on the carbs or nothing. Easy to fit. Recommended.
Sam K
« Reply #28 on: July 22, 2008, 02:33:21 am »
I bought a set of those filters from Dave Greiner in April and I've been very pleased with them. I know a couple other guys who have them and are happy as well.
« Reply #29 on: July 22, 2008, 03:28:54 am »
I have them but still like the looks of open stacks...just depends on whether or not your an "air filter" guy.  If I was commuting in my car every day, MAYBE I'd think about using them, but for Saturday Sunday cruising, I'm out.  Also, for you guys who have notched the #2 cylinder velocity stack for deck lid clearance, you may have interference problems with the screen contacting the deck lid.
