September 22, 2026, 06:14:12 am
| | |-+  Need Jetting Help With The DCNF's
Author Topic: Need Jetting Help With The DCNF's  (Read 5460 times)
« on: July 18, 2013, 00:54:35 am »
Like the subject says, Haven't  played with DCNF's in years, until now. Motor is a 82X94, Web-Cam #100, heads are 42X37 wedge port. Need a started point, Idles, Mains, and Airs. The DCNF's are 42 Berg Specials W/short Type III manifolds. Any idea's?HuhEmbarrassed  Grin
Ted
« Reply #1 on: July 18, 2013, 02:23:13 am »
I'd start with 55 idles, 180 airs and 145 mains.  Make sure you have F25 emulsion tubes.  The idle may be a little fat, but you can adjust that accordingly.  It should get you pretty close.
« Reply #2 on: July 18, 2013, 13:11:23 pm »
I used "DCN's" but this thread might help  Smiley
http://cal-look.no/lounge/index.php/topic,6900.0.html
« Reply #3 on: July 18, 2013, 21:11:27 pm »
try the same combo as idf's would be jetted. this seems to be a good approach in my book. the emulsion tubes are indeed F25's if memory serves me right.
alstare84
« Reply #4 on: July 18, 2013, 23:03:06 pm »
some notes of what I got from the web because I have the Berg Specials and in the 1776 that I'm building I'll use them. I didn't checked again my notes, just copied and pasted here:
http://www.shoptalkforums.com/viewtopic.php?t=27951&highlight=berg+carbs
180 airs, 55/50 idles, 135/45 mains.
http://www.geneberg.com/product_info.php?cPath=8_260&products_id=878
http://www.thesamba.com/vw/forum/viewtopic.php?t=392709
http://www.knfilters.com/search/product.aspx?Prod=E-3930
Mains: 140
 Air Correction: 170
 Emulsion: F25
 Idle Jets: 65
"Straights are for Fast Cars... Corners are for Fast Drivers!"
'60 Ragtop L436 Indigo Blue
'65 Sedan L87 Pearl Weiss
« Reply #5 on: July 21, 2013, 02:42:43 am »
This is what in them now.. 60 Idles, 140 mains, 180 airs, and F-25 emo tubes.
« Reply #6 on: July 21, 2013, 08:49:46 am »
i assume the airs are too small. but i can work as a good starting point. you may need to go bigger in air and mains, the idles will be big too, but you'll have to see for yourself the exhaust color. 55 or 60 must work. 50 will be too small for the big engine.
