November 02, 2026, 15:48:13 pm
working on the 67
5
6
7
8
9
Topic: working on the 67 (Read 234042 times)
Richyrich
Re: working on the 67
Reply #150 on:
May 14, 2012, 23:11:06 pm »
Very Sweet, You do good work.....
thehanz DVK
Reply #151 on:
July 06, 2012, 14:43:37 pm »
some progress...a lot of little stuff
fuelline's are ready
oillines are ready
brakelines are ready
only the clutchline's must be finisched and the put some fluids in and hopefully they stay in
made a board to put all MSD and NOS on....
started some final assembly on the engine
interior can be picked up next week
car must be ready and fully tested for next season don't wanna mis EBI
and some pic's
Jesse/DVK
'64 2176cc
Reply #152 on:
July 06, 2012, 14:53:43 pm »
Hurry up!!
Nice work Hans!
tikimadness
Reply #153 on:
July 06, 2012, 15:04:05 pm »
It's amazing that you can still get wise out of all these things
Top work Hans
GASSER GARAGE a few friends creating history.
NIDGAFWYT
Wunder Wim
Reply #154 on:
July 06, 2012, 18:57:03 pm »
Very nice indeed Hans
Reply #155 on:
July 08, 2012, 13:47:22 pm »
Quote from: thehanz on July 06, 2012, 14:43:37 pm
oillines are ready
and some pic's
Hanz
the car build is really good,lots of nice detail,well done
2 things I noticed,the blue vent tube for the nitrous bottle needs to vent outside the car,do you have a hole for it to go out of? and with big torsion bars[not sure what size you have?] you dont really want to use the bus bump stop/snubbers,they are ok for on the street but can cause problems on the track,and when the car is together you may need to shorten them,you need about 25mm clearance from the top of the rubber to the bump reciever on the body
Keep up the good work
thehanz DVK
Reply #156 on:
July 08, 2012, 16:26:25 pm »
hello richie
the hole for the blow off tube is not drilled yet, that's on the to do list and the bus snubbers are not needed then for me i have the 30mm torsionbars so the i put the original rubber in ?? thanks for the advice...
i also heard (from tiki michael) you had NOS a few years ago so maybe i will send you a pm with some questions about it, when i do progress a little with it.
thnx hanz
Reply #157 on:
July 08, 2012, 16:38:23 pm »
Quote from: thehanz on July 08, 2012, 16:26:25 pm
hello richie
thnx hanz
The original rubber is even harder,you can get thin bump rubbers or shims that fit around the shock absorber shaft,thats all I would use,I dont run any bump stops on the old cabrio with 30mm bars and QA1 shocks,if you drive on really bumpy roads then you can use the bus bump stop cut down shorter to act as limiting device,nothing more.
When you are ready ask away on the nitrous stuff,still got some good info stored in my brain
cheers richie
thehanz DVK
Reply #158 on:
July 08, 2012, 19:46:00 pm »
Quote from: richie on July 08, 2012, 16:38:23 pm
hello richie
thnx hanz
cheers richie
thanks richie it''s apriciated
thehanz DVK
Reply #159 on:
July 14, 2012, 11:37:40 am »
today i picked up the two seats and half of the backseat....next week the rest off the parts...
and i am very
it even smells as good as it looks
thehanz DVK
Reply #160 on:
July 19, 2012, 19:30:27 pm »
doorpanels are also in....i am happy...again
Eddie DVK
Reply #161 on:
July 19, 2012, 21:58:40 pm »
Whooo, very cool color. looks really nice
Regards Edgar
Regards Edgar
Dokke/DFL
Reply #162 on:
July 20, 2012, 09:28:24 am »
It's really AWESOME !!!
max2919
Reply #163 on:
October 04, 2012, 20:54:05 pm »
We want to se more!
VW 57 Ghia RLR 2919cc TURBO!
Porsche 356A Coupe replika.
thehanz DVK
Reply #164 on:
October 04, 2012, 21:12:10 pm »
this weekend i Will take Some pictures all the little stuff taking ages
max2919
Reply #165 on:
October 04, 2012, 21:26:57 pm »
Reply #166 on:
October 05, 2012, 10:34:34 am »
Looking good!
I noticed that you`re using the CSP tower style breather box and inlets are:
1) The alternator tower, approx 19mm
2) The fuel pump block off, AN 10
Not sure if the AN10 fitting in the 3/8" on the right hand side of the box is there to let breath out? If not out your current outlet is a fitting in the 1/2" NPT. You should reconsider this or at least make it as big as absolutely possible. I have the same box and modified my outlet to 34mm. I have more volume out than in.
-BB-
cedric
Reply #167 on:
October 05, 2012, 20:21:54 pm »
Nice work cant wait to ebi
thehanz DVK
Reply #168 on:
October 06, 2012, 12:59:10 pm »
Quote from: BeetleBug on October 05, 2012, 10:34:34 am
Looking good!
-BB-
Mhhhh thinking you are right ..... Will keep it in mind
Last Edit: October 06, 2012, 13:46:12 pm by thehanz
thehanz DVK
Reply #169 on:
October 06, 2012, 13:49:49 pm »
and some picture's, the front off the car is getting there, at the moment the BRM's are on and the bumpers, for the normal cruize mode, and for the DDD weekend and so one i have centerline's and Tbars so every now and then i will change over
picture off the front and from under the hood..
thehanz DVK
Reply #170 on:
October 06, 2012, 13:55:50 pm »
Also got my manifolds shortend by Steve from Steve's vw shop so hoppefully the lid closes now, it got shorter and it also flows more air also as a bonus, so i can get on with the NOS instal on the engine, some pic's from the carb's and manifolds.
and said before, i probably gonna make a bigger breatherfilter and i also have to modify one off the airoquip fittings because as is now it doesn't clear the fuellhose and carb, so a little bid of welding drilling and new coat and it will also fit..
Last Edit: September 12, 2013, 21:54:32 pm by thehanz
thehanz DVK
Reply #171 on:
October 06, 2012, 13:57:05 pm »
and a shot off the berg shifter and the instruments...
still waiting on the upholstry shop, hopefully in two weeks it will go there and a month later it will be back, can waith to see the result, it will finish the car a lot futher for sight..
Last Edit: October 06, 2012, 13:59:44 pm by thehanz
pupjoint
Reply #172 on:
October 06, 2012, 15:20:29 pm »
very nice
thehanz DVK
Reply #173 on:
October 27, 2012, 13:00:40 pm »
thank you all for the friendly word's
today at the upholstery shop 2 67 ragtop's thei beige one is a original 67 standard and mine and the daily , three 67's in a picture 67 heaven
fahrvergnugen
Reply #174 on:
October 27, 2012, 20:12:27 pm »
Nearly there, almost time to drive the MF. Looking good.
http://fast-air.skynetblogs.be/
cedric
Reply #175 on:
October 28, 2012, 18:06:11 pm »
Hey that's rene from kevermagazijn he is the best...
thehanz DVK
Reply #176 on:
October 28, 2012, 18:11:08 pm »
Your right Cédric thats why the car is there hè is the master with à ragtop
coxwagen
Reply #177 on:
October 28, 2012, 18:21:51 pm »
so sweeeeeeeeeeeet
Oliv from Veedubs Haus
miguel
Reply #178 on:
October 29, 2012, 22:54:29 pm »
with Rene his in good hands to make it perfect
thehanz DVK
Reply #179 on:
November 02, 2012, 18:30:49 pm »
in the previous picture's there was a wooden empi steering wheel, that's in the daily now...
last week the other wheel was ready newly rapt in black leather and new repop hornbutton, i am happy with it will look good with the black dash
5
6
7
8
9
