October 13, 2026, 15:27:03 pm
what clutch ?
Topic: what clutch ? (Read 5651 times)
ED2.4
what clutch ?
August 18, 2013, 14:22:45 pm »
Hi all,
i wondering what type of clutch assy i must use on my project,
i have a Mendy MD4S with a differential (long ratio) with G50 spline and a 2919cc (in the build) efi turbo engine , expected to produce approx 500hp @ 25psi and 7500rpm max in race configuration, and 350hp @ 15psi in street use ,
vehicle will be a '64 split bus (highly modified), final weight with driver is around 2600 Lbs , 80% street use with radials tires and 20% racing with 8" slicks,
i primary think to a Kennedy dual disc kit with a stg3 PP and no Clutch management,
6 pucks disc?4pucks?sintered?
otherwise , a dual J&G/McLeod assy(with the light PP) ? i don't think it's ideal for street use?
or a RLR Rev 6 ?someone have tried the diamond back from ACE with a stg 3 ?
what are you thinking about that?
thanks in advance for your advise
Eddy
Last Edit: August 18, 2013, 14:39:29 pm by ED2.4
DeluxeRacingTeam >>>>
http://charlie48ida.skynetblogs.be/
ED2.4
Re: what clutch ?
August 20, 2013, 14:33:35 pm »
Hi,
come on guys ! Give me some inputs please
thanks
Eddy
Re: what clutch ?
August 20, 2013, 16:09:32 pm »
i HAVE A 2919/NOW A 2963 -- replied to you on UAC
http://selvedgeyard.com/
ED2.4
Re: what clutch ?
August 21, 2013, 14:12:07 pm »
Thank you Fiatdude,
replied on UAC
Re: what clutch ?
August 21, 2013, 16:00:55 pm »
Eddy
PM sent
ED2.4
Re: what clutch ?
August 22, 2013, 08:29:10 am »
Thanks a lot Richie !
Eddy
